amailloux Posted February 20, 2014 Share Posted February 20, 2014 I have my first RH manifold gasket leak. I have done up pipes with a partial cab lift, but haven't had the pleasure of a manifold yet. How do you guys go about doing these things. Labor time is a little weak to be messing around. Anyone care to share? It is a 2wd f-550. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 20, 2014 Share Posted February 20, 2014 I just finished one up a week ago, had two broken bolts. I pulled the cab, disconnected the right side engine mount and raised the engine with a crane and slipped a 2X4 under the mount to hold the engine up. This gave me plenty of room to drill out the bolts and install thread inserts. I have another waiting to come in for the same exact repair. Quote Link to comment Share on other sites More sharing options...
lmorris Posted February 20, 2014 Share Posted February 20, 2014 I you have no broken bolts, you can remove the A/C compressor and remove it out the front. That way you are not messing around with the turbo up pipes and down tube. Remove the inner fender and upper fan shroud. Isn't any faster, but it's nice not having to do anything with the up pipes. 2 Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 20, 2014 Share Posted February 20, 2014 If it's customer pay and not a regular cab I would yank the cab off. I've done them both ways and I prefer to have the cab in the air. Quote Link to comment Share on other sites More sharing options...
amailloux Posted February 20, 2014 Author Share Posted February 20, 2014 She's done, pulled the fan and alt bracket. Pulled her out the front. Then spent 1 hour getting the 2 broken studs out. I left the a/c compressor in and just removed the lines. One of the crappier jobs I have come across on the 6.4. 5.9 hours plus time to remove broken bolts. left hand pays 8 and I think is easier. Oh well. Quote Link to comment Share on other sites More sharing options...
batmantech Posted February 21, 2014 Share Posted February 21, 2014 Curious what you used to remove the broken bolts....??? Quote Link to comment Share on other sites More sharing options...
amailloux Posted February 21, 2014 Author Share Posted February 21, 2014 They were broke off just below flush. 1 twisted of when removing, and the other was gone. I took a very small die grinder and cleaned them up until they were shiny. I pulled out the welder and built them up above the head and welded a nut on them. I got them to turn and the stud promptly broke again: a few nuts later and slight sunburn and I finally got them out. Have been using the mig for a long time now. I'll clean and weld for an hour before I pull out the drill. I hate drilling bolts. Quote Link to comment Share on other sites More sharing options...
batmantech Posted February 21, 2014 Share Posted February 21, 2014 I too will weld a long time before I drill anything! I was beginning to wonder if I missed something with all this talk about drill guides lately. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 21, 2014 Share Posted February 21, 2014 Not everybody has welders. Besides, I have gotten really good at it so it doesn't phase me anymore not to mention that I don't think you can use the welding method on everything especially fasteners broken well down below the surface. Correct me if I am wrong about that as I have zero experience with that approach. Quote Link to comment Share on other sites More sharing options...
amailloux Posted February 22, 2014 Author Share Posted February 22, 2014 I see a ton of 6.0 gas chevy engines with bolts broke off below the surface of the aluminum head. I'll snap some photos next time. Quote Link to comment Share on other sites More sharing options...
Fredsvt Posted February 22, 2014 Share Posted February 22, 2014 The welding approach works well for below flush broken bolts. Since I'm not a talented welder, the guy in the big truck shop next to us will come over and do it. Got 7 broken flush and below flush out of a 5.7 Dodge 'hemi'. These things just EAT manifold bolts and manifolds. That day was two identical 2500 pickups, each truck had multiple broken bolts on both sides and needed manifolds. Worked great on a 6.0 gas GM, left rear manifold bolt was 3 threads below the surface. 1 Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 22, 2014 Share Posted February 22, 2014 Keith I had a fleet customer turn in a 03 6.0 turbo as a core with the rear bolt not only broken off but they tried to melt it out with a torch. Not only was it more than 2-3 threads below flush but it was a dirty glob of molten slag. I built that stud up and when I pulled it out the remaining bolt cleaned the threads up on the way out. The shop manager was pissed at his guys when he found out I saved that turbo. 1 Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 22, 2014 Share Posted February 22, 2014 Not everybody has your skills Matt - that just adds to your reputation. Did the core finally get returned or did you do that just for the fun of it? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 22, 2014 Share Posted February 22, 2014 Where do you think the one came from that's in his glass case for his art exhibit? Quote Link to comment Share on other sites More sharing options...
Aaron Posted February 22, 2014 Share Posted February 22, 2014 I don't remember who posted it, it may have been on here. Someone was saying they drill the stud and then hammer a cheap torx socket into it. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 22, 2014 Share Posted February 22, 2014 Nah, must have been one of them other forums you frequent, you know hackersforlife.net Bahahahaha Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 22, 2014 Share Posted February 22, 2014 I bought a junk turbo off Craigslist for $50. Put that in the core box and kept the good one. I ran it on my truck for a while to make sure it was good then sold it for $300 I've flipped a few turbos now. The glass case turbo is on a f-550 and the one I just recently uploaded pics of got put on my truck today. Quote Link to comment Share on other sites More sharing options...
DieselD Posted February 22, 2014 Share Posted February 22, 2014 Not everybody has welders. Besides, I have gotten really good at it so it doesn't phase me anymore not to mention that I don't think you can use the welding method on everything especially fasteners broken well down below the surface. Correct me if I am wrong about that as I have zero experience with that approach.Every situation is different and one more method in your toolbox can save your butt on getting a bolt out. I have done the welding method before and it works well but I wouldn't call it the end all be all method. I can remember several times I have gone to grab the welder and it's in use, out of wire or gas etc. then it's on to plan B to get the job done. Quote Link to comment Share on other sites More sharing options...
