Brad Clayton Posted March 28, 2014 Share Posted March 28, 2014 A warning to heed for sure: 21643 STEERING/SUSPENSION SERVICE TIP - DEPOWER EPASSOME 2011 F-150 VEHICLES EQUIPPED WITH EPAS (ELECTRONIC POWER ASSIST STEERING) MAY REQUIRE STEERING SYSTEM OR FRONT SUSPENSION SERVICE. THE EPAS STEERING GEAR ASSEMBLY MAY BE DAMAGED IF ANY STEERING/SUSPENSION COMPONENTS/FASTENERS ARE SUBJECTED TO A HAMMER BLOW OR AN IMPACT WRENCH DUE TO ARCING OF THE CONTACTS IN AN INTERNAL POWER RELAY EVEN WHEN THE IGNITION IS OFF. DISCONNECT THE ELECTRICALPOWER TO THE EPAS MODULE BEFORE PERFORMING ANY STEERING/SUSPENSION SERVICE. POWER CAN BE INTERRUPTED BY DISCONNECTING THE POWER STEERING CONTROL MODULE CONNECTOR C1463A. IF THE SYSTEM IS NOT DEPOWERED PRIOR TO SERVICE, AN EPAS WARNING MAY BE DISPLAYED IN THE MESSAGE CENTER ALONG WITH DTC U3000:49 WHICH REQUIRES REPLACEMENT OF THE EPAS ASSEMBLY. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 28, 2014 Share Posted March 28, 2014 aaaaaaaaand denial of warranty. Quote Link to comment Share on other sites More sharing options...
Aaron Posted March 29, 2014 Share Posted March 29, 2014 Clipping a curb just got a shit ton more expensive too... Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted March 29, 2014 Share Posted March 29, 2014 This almost sounds like experience talking? There is just way too much to remember any more. Seems like you need to run OASIS for EVERYTHING. I wonder what a loose tie rod end on a rough road could do? Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 29, 2014 Share Posted March 29, 2014 I wonder what a loose tie rod end on a rough road could do? ....... or a "loose cannon" in a shop will do. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted April 4, 2014 Share Posted April 4, 2014 I can't wait for the first call from an independent shop that just put a tie rod in. Quote Link to comment Share on other sites More sharing options...
DieselD Posted April 4, 2014 Share Posted April 4, 2014 Something to keep in mind for sure. I have several of these I could be working on in the near future Quote Link to comment Share on other sites More sharing options...
