SSM 44479
forddieseldoctor
SSM 44479 - 2013 Escape - Complete FSA 13S12 Prior To PCM Reprogramming - Multiple Cooling System Codes After Powertrain Control Module Update
Complete Field Service Action (FSA) 13S12 prior to reprogramming the Powertrain Control Module (PCM). Some 2013 Escape vehicles equipped with a 1.6L engine may exhibit multiple cooling system DTCs after PCM reprogramming. DTCs P1299, P2556, P2557, P2560, P1940, and U1035 may be induced if the PCM is reprogrammed before 13S12 is completed. The FSA steps must be completed in the proper sequence provided in the FSA. Upon completion of the FSA, clear all DTCs and retest. Prior to performing the following Technical Service Bulletins (TSB's) FSA 13S12 must be completed: 13-02-15, 13-03-14, 13-03-15, 12-10-13.
When you run oasis for a P26B7:00-28 (PCM) - Engine Coolant Bypass Valve C Control Circuit Open you come up with TSB 13-02-15 for a new vavle and a reflash, but what they don't tell you on oasis for that code is that this ssm exists until after you flash it and get the pile of codes that won't clear.
