BigWalt Posted April 14, 2014 Share Posted April 14, 2014 PTS site is down, got no where with PTS today. I got 2012 F450 with 6.7 diesel. Loud noise coming from engine, louder when removing air filter box.Sound like hoover vacuum cleaner. It does sound like turbo or waste gate going out. Does anybody has experienced with that noise? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 14, 2014 Share Posted April 14, 2014 Turbo bearing failure -,makes that sound because the compressor and turbine wheels are contacting the housing Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 14, 2014 Share Posted April 14, 2014 yes many cab and chassis turbo failures. Be sure to check the turbine for blades missing and retrieve them from the exhaust. Also bathing the intercooler is recommended Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 15, 2014 Share Posted April 15, 2014 Actually Ford recommends replacing the charge air cooler if there is a lot of metal Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 15, 2014 Share Posted April 15, 2014 The only one I replaced had actual shards of metal stuck in it. All the others seemed to clean out okay. I suppose if you can see metal getting into the cold side duct it's time to replace it. Quote Link to comment Share on other sites More sharing options...
