amailloux Posted April 18, 2014 Share Posted April 18, 2014 Any tips? I have 1 to do. I see the cable is what makes you have to remove the heater box. Any good tips to get the dash and box out? Also has a bunch of aftermarket wiring arrggggg. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 19, 2014 Share Posted April 19, 2014 I believe I did one plenum chamber about a year ago. I don't recall much about it but I do know that it was relatively easy to get the dash out and replace the chamber. Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 21, 2014 Share Posted April 21, 2014 I just hauled the dash out of an 08 150 what a piece of cake. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted April 22, 2014 Share Posted April 22, 2014 They are cake - I did a couple evap cores not too long ago. Easier still if they are gas jobs. I leave one bolt on the driver's side loose but attached. The whole dash will pivot around the l/front a-pillar. All you really need to disconnect is a couple electrical connectors on the left side of the dash, the park brake cable from the release handle, the steering shaft and a couple more connectors around the SJB on the other side I get the a/c lines by taking out the inner fender and going in from the bottom. The dash pivots enough to have it rest on the passenger's seat. From there it's easy access to the plenum nuts and bolts, and if it's gasoline then the ones in the engine bay are pretty easy, too. Quote Link to comment Share on other sites More sharing options...
amailloux Posted May 1, 2014 Author Share Posted May 1, 2014 Went In on That saturday and knocked it out pretty quick. Not bad at all, other than all the aftermarket black box gps stuff wired in everywhere. Quote Link to comment Share on other sites More sharing options...
