YukonTyler Posted April 19, 2014 Share Posted April 19, 2014 Have this truck in for black smoke on aggressive takeoff, poor performance, p0299. I drive it and notice no wastegate operation. Called turbochargers on it. Ordered the two turbos, gaskets and hardware. New turbos arrive. Right side bolts in great. Left side is missing the casting on the compressor which acts as the lower mounting hole. I ordered another turbo - same thing arrives. Is there a change up on these that I'm not aware of? Is my parts department ordering it incorrectly? I can't see Ford doing away with this mounting provision, let alone only doing it on one side. I'm going to the shop now - pictures to follow afterward. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 19, 2014 Share Posted April 19, 2014 I would say a call to Ford is in order to get to the bottom of this one Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted April 20, 2014 Share Posted April 20, 2014 The guy next to me just put a turbo in and it did not have that mount either. It fixed the turbo noise, the wheel was hitting the housing. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted April 22, 2014 Author Share Posted April 22, 2014 Thanks for the feedback. I wound up slapping it in. That's not a fun job. The coolant lines neither like to disengage or re-engage with their quick connect fittings. It seems you have to pop out the quick connect clip, work the line in with a suitable tool, and then fool around getting the clip back in its rightful spot. I spent way too long fooling with those two lines. In happy news the wastegates now function. Sadly I also found the plugged cats and gasoline-grown engine oil level which caused the issue in the first place. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted June 8, 2014 Author Share Posted June 8, 2014 Update - did another turbo on a different unit the other day. I went digging for torque specs and the WSM now notes that the lower mounting bracket is no longer needed. 1 Quote Link to comment Share on other sites More sharing options...
