2004 hpop
Those specifications are hard to find but they are listed in the Coffee Table Books under the Special Torque Chart. Could not tell you why this was not included in the WSM - or at least I could not locate it. Although I have had several apart I do not recall whether  the bolt is a left or right hand thread and I do not want to guess. This is not something that is normally supposed to be serviceable as the pump is typically serviced with the gear. Anyway, from what I can find, the specs for ALL 6.0L and 4.5L HPOP Drive gears is:
  • 95 lb/ft or  129 Nm
I had one a couple of years back that came loose just after I installed a new reman, I just got in the habit of checking the torque befor installing the pump, but forgot the spec. thanks Keith
