1993 7.3 idi
hmm i don't think i even knew about those rubber seals, is there one in each hard line? i'm going to reseal the other bank of injectors, and change those seals and perform a vaccum test and hopefully it holds. Keith is that the part number for the seal kit I will need? Hopefully my dealer will be able to find a parts break down for the o-rings or at least a size so I can pick them up in viton
I figured out what is in the kit and this kit actually is not what you need. Sorry bout that. The part number I listed has the following sizes:
    [*]4 - 1/4" sleeves [*]1 - 5/16" sleeve [*]1 - 3/8" sleeve
If I recall you need one 3/8" sleeve for the fuel pump to filter head line and two 5/16" sleeves for the filter head to injection pump line.
I found these part numbers:
Fuel line seals--filter to injection pump E3TZ-9K260-A
Fuel line seals--fuel filter inlet; return line from injection pump (rear only on some applications)   E3TZ-9C387-A
    [*]4 - 1/4" sleeves
    [*]1 - 5/16" sleeve
    [*]1 - 3/8" sleeve
thanks keith, it's greatly appreciated!
