PCM
Jeff Clyde
I'm trying to find a PCM for a 2000 Excursion, 7.3. Not available from Ford, or through the auto wreckers on the Canadian hotline they use.Tag number is YC3F AVA
Any help would be great !
Looking at a very old document(that I just happened to find on an old drive about 3-4 days ago, good timing!) Try a 2000 Excursion 1C3F-AA/AB/AC/AD, YC3F-AVB or a 2001 Excursion XU7F-CA. Theres a few others that are from the same family that I can list up the tag numbers for as well if you want to try, then you should be able to lie thru IDS and blank path program it to what you want I believe so long as it's a type DPC-452.
  • Like 2
I'm trying to find a PCM for a 2000 Excursion, 7.3. Not available from Ford, or through the auto wreckers on the Canadian hotline they use.Tag number is YC3F AVAAny help would be great !
What is wrong with original unit?  I've had a couple fixed at SIA electronics.  http://www.siaelec.com/
