BigWalt Posted August 7, 2014 Share Posted August 7, 2014 2014 F350 with 6.2 engine, second time in less than 3 weeks TFT sensor failed.I did a Pinpoint test B, TFT sensor resistance reads open.Removed trans pan, check resistance at the sensor, same result.Anybody come across with repeat TFT sensor failure? Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted August 7, 2014 Share Posted August 7, 2014 We just had a 2015 setting different codes but the problem was with pin fit at the tcm. Take a look at the tcm and see if there any pins that look darker. Don't know if this helps, just thought I'd put it out there. Quote Link to comment Share on other sites More sharing options...
BigWalt Posted August 7, 2014 Author Share Posted August 7, 2014 There is no TCM, just PCM. I will look at PCM tomorrow.Thanks Quote Link to comment Share on other sites More sharing options...
