Buddy_M Posted August 25, 2014 Share Posted August 25, 2014 I picked up a 2000 Focus with the 2.0 SOHC motor a while back for a more efficient daily driver. While out a few weeks ago I noticed the coolant smell and after tearing it down proceeded to find the water pump had been leaking and head gasket blew. Check the head and could see daylight under a straightedge so thats beyond saving(takes too long to ship stuff to a machine shop here to deck it usually, so I'm looking at reman heads right now to also beat the intake seat issues) but the block even has a little bit of warpage, more than the MLS gaskets call for. I'm wondering if anyone has thought about or installed the 99-older composite gaskets from the same motors into the newer vehicles as it should compensate for the warp. As far as I can see physically, the gasket layout is the same, as well as torque specs and head bolts so I don't see why it cant work, just tryin to get some feedback on this thought since I'm not looking to turn this into a money pit by pulling the engine for machine work or replacing the engine at this point if I can help it. Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 25, 2014 Share Posted August 25, 2014 Why not use an aftermarket composite gasket designed specifically for that year? Quote Link to comment Share on other sites More sharing options...
Buddy_M Posted August 25, 2014 Author Share Posted August 25, 2014 I haven't found anyone that lists composite gaskets for the newer engines, maybe my google skills are just going down, but none of the major manufacturers have listed an alternate that I could find. The random thought had just popped into my head last night of the older engines have a bigger warp tolerance so I compared the MLS gasket to a picture of the older composite online, and looked up a few associated parts to see if they were shared between the years with the gasket change. I'm going to order a early style gasket this afternoon to compare and if it lines up it definately will be an option I consider trying, at least its not hard to pull a head out of these cars if I have to do it again. Quote Link to comment Share on other sites More sharing options...
