E4OD Solinoid Body Connector
Mekanik
Hey guys, I'm replacing the transmission on a 99 F350 with a 7.3L and an E4OD.  The tab on the solinoid body connector (right side of transmission) broke off.  The part is completely obselete from Ford, but I was hoping some of you may have crossed this bridge and have found a solution.  Maybe an aftermarket connector?
Thanks in advance,
Jim
36445EAK in my Transtar catalog lists it for the DTR sensor, but all the pictures it appears to be for the solenoid pack by the shape(Just looked odd not matching up, just be worth it to double check it before ordering). WPT-590/3U2Z-14S411-VCA shows up quite a bit in the partsvoice locator, so your parts guy should be able to get one thru that channel if the warehouse doesn't have it, but even Rockauto showed they have the motorcraft part available to ship from typing the numbers into google.
