8WA Sman Posted November 14, 2016 Author Share Posted November 14, 2016 Disclaimer smoke from plastic can be toxic ....Be safeI had found that a solder gun with a flat tip works well for welding plastic pieces. I prefer to use the original material if possible. Let say you have a trim piece the broke one of the factory welds, if there is enough material remaining just heat it up, if not cut a non used ear off the piece and use for a filler rod. Also string trimmer string works great for a filler rod....FYI if repairing a DPF sensor port on a 6.4L it will only make it about 1/2 way through a Manual Regen befor it melts the string trimmer string filler 1 Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 26, 2017 Author Share Posted May 26, 2017 I started using dishwashing soap & water to clean my safety glasses. Put a couple drops of soap, rub between your finger & thumb, rinse with water. Then blow dry with shop air....your glasses are now anti-fog 1 Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 8, 2018 Author Share Posted May 8, 2018 I got these in today. Anyone care to guess what they are used for? 1 Quote Link to comment Share on other sites More sharing options...
cbriggs Posted May 8, 2018 Share Posted May 8, 2018 Probably not what they are meant for but I bet they would work for disconnecting the heater hoses on most ford vehicles. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 8, 2018 Share Posted May 8, 2018 Quick Connect fuel lines? I know those are Knipex. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 8, 2018 Author Share Posted May 8, 2018 They are 9" fuel hose line clip adapter disconnect release tool.I think I am going to really like them, especially on 6.7 Def filler hose @ the tank Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 8, 2018 Share Posted May 8, 2018 YES! Tool number please? Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 8, 2018 Author Share Posted May 8, 2018 Sorry no number on the tool but here is a link https://www.amazon.com/Adapter-Disconnect-Loosening-Plier-Release/dp/B01J0P9YGG Quote Link to comment Share on other sites More sharing options...
batmantech Posted May 8, 2018 Share Posted May 8, 2018 That would be nice to try out. FYI I quit even attempting to remove the def tank hoses at the tank. They are usually full of mud, gravel. I unbolt them at the fender and pull them down with the tank. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted May 15, 2018 Share Posted May 15, 2018 On Tuesday, May 08, 2018 at 3:10 PM, batmantech said: That would be nice to try out. FYI I quit even attempting to remove the def tank hoses at the tank. They are usually full of mud, gravel. I unbolt them at the fender and pull them down with the tank. I used to take the lines out with tank then I bought these and have been removing the lines from tank again https://store.snapon.com/Diesel-Exhaust-Fluid-DEF-Tools-Diesel-Exhaust-Fluid-DEF-Tube-Release-Forks-P886427.aspx 1 Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted May 16, 2018 Share Posted May 16, 2018 Itonly works good on stock pickups removing lines with tank. Then any upfit pickup and all cab and chassis that method doesn't work. So that's when I found the disconnect tools. I probably work on 70 percent upfit so leaving lines attached not feasable Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 17, 2018 Author Share Posted May 17, 2018 I got these a couple weeks ago for doing front shocks on E-Series vans. The 21 mm works for the top nut. https://atdtools.com/99652 What is everyone else using to remove the drivers side, I usually end up cutting them off. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 17, 2018 Share Posted May 17, 2018 I cut them as well if they are really difficult. I have a ratcheting box wrench that usually works but space and swing room is limited. Good or bad I really don't do many shocks on E-series to begin with. Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 14, 2018 Share Posted June 14, 2018 I took my old spark plug wire removers and modified the ends to do the same thing for removing fuel lines and the DEF tank hoses. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted July 23, 2018 Share Posted July 23, 2018 I have found these helpful. https://www.lislecorp.com/specialty-tools/disconnect-tools/disconnect-pliers 1 Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted August 2, 2018 Share Posted August 2, 2018 I modified an otc 6541 and it works excellent to remove the dually rear center caps Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 11, 2018 Share Posted August 11, 2018 On 7/23/2018 at 3:54 PM, tonybullitt said: I have found these helpful. https://www.lislecorp.com/specialty-tools/disconnect-tools/disconnect-pliers I just bought these - so far happy with it. Quote Link to comment Share on other sites More sharing options...
