the_twig_187 Posted February 18, 2015 Share Posted February 18, 2015 having a really hard time finding a part number for the valve cover wedge that keeps the inside of the injector Harness from backing out of the valve cover connector. anyone know what the part # is? I thought it was a TSB back in the day but I cant find that either thanks Chris Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 18, 2015 Share Posted February 18, 2015 From the under cover harness to the valve cover gasket. Quote Link to comment Share on other sites More sharing options...
Buddy_M Posted February 18, 2015 Share Posted February 18, 2015 Don't use it with a new harness, you will break the tab off(Done it myself). The new harness has a raised part under the tab so these aren't needed. However if I come across a truck with a loose harness, I quote for a new harness. Hard to say if the pin sockets are worn as well and still may present a problem to the customer after a short time. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted February 18, 2015 Author Share Posted February 18, 2015 thanks guys Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 18, 2015 Share Posted February 18, 2015 I install them if I'm under the covers for something else not related to the wiring, kind of as preventative not for a repair. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted February 19, 2015 Author Share Posted February 19, 2015 so this is the new updated retaining wedge, it is much larger and fatter than the original clips. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 19, 2015 Share Posted February 19, 2015 Interesting Could you get a picture of that installed? I haven't put a wedge in for years. When I have any concerns with wiring I have been replacing the uvc and gasket. Quote Link to comment Share on other sites More sharing options...
Fordracer Posted February 19, 2015 Share Posted February 19, 2015 That looks like the retainer for the valve cover connector outside of the valve cover not the one under the valve cover. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 19, 2015 Share Posted February 19, 2015 The parts catalog is wrong when listing the wedge, the part I have taken a picture of is the correct part. The 1C3Z number is the external wedge. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted February 19, 2015 Author Share Posted February 19, 2015 yah that wedge is not for the inside of the valve cover. another tech had the proper wedge in his goodies bin and I was able to use that one to repair the vehicle. I had the parts guy run the number on the picture Matt posted and the cpu says the part is discontinued and was not replaced by another part so im not sure how you would get a hold of a wedge anymore? perhaps they want us to replace the inside harness and gasket as the fix Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 20, 2015 Share Posted February 20, 2015 Really? I just got that pack in last month. DOW shows 669 units left. Ontario shows 52 Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted February 20, 2015 Share Posted February 20, 2015 That wedge was crazy expensive the last I checked a long time ago, I use a pair of 4" tie wraps to lock the connector together. I have pics and the wedge PN at home but not with me now...... Quote Link to comment Share on other sites More sharing options...
DieselD Posted February 20, 2015 Share Posted February 20, 2015 typically just been replacing the harness on them if they come loose. With the age and mileage of the 7.3 now days its cheap insurance Quote Link to comment Share on other sites More sharing options...
