5w40 full synthetic
Here is the latest response from hotline about a turbo concern. This time they do say its because of the cold temp.
With the colder temperatures that the Minnesota area has been seeing it would be recommended to change the engine oil to a winter viscosity such as SAE 5W- 40 full synthetic diesel motor oil or SAE 15W-40 full synthetic diesel motor oil. Changing the oil viscosity will improve VGT response time and reduce the drag on the bearings in the turbocharger when the oil is cold.
I was also given that reply about an overboost code, switch to 5/w40 to improve response time of the vgt. Make sure you keep a copy of that reply for fmpp services, they don't like paying for 5/40 anymore. We can only get 5/40 to go though between October and March, otherwise they decline it and say 10/30 is fine for summer time.
I had one a couple months ago that had a P259F and P0236 and the hotline had me replace the turbo and run 5W-40 in it. It came back yesterday with only the P259F and it has 7,000 miles on it since the repair. He said everything was fine since we put the turbo on it until the light came back on. FF data shows the VGT CMD was 15% and the VGT ACT was 0%. Hotline said to replace the VGT and run 5W-40.
