RyanG Posted March 19, 2015 Share Posted March 19, 2015 anybody run into this issue yet. 2011 6.7 cab and chassis f350. longer than normal cranking time. p0087 low fuel pressure stored. ran all pinpoint test checks, found no issues. truck runs great, 230,000 miles. removed fuel pressure control valve and volume control valve, no contamination, good clean fuel in tank- tank and low pressure pump replaced 15000 miles ago for delamination. replaced both vcv and pcv and still have same issue. fails high pressure fuel system test every time. im a little fuzzy on the cylinder balance pids. pinpoint test asks if they are relatively close to each other. all 8 are between +/- 0.00 and 0.02, that seems pretty close to me. relative compression and power balance look great. Im wondering if high pressure pump is on the way out, anybody have any ideas or possible things im overlooking. low pressure fuel system is showing 60 + psi under load after secondary fuel filter. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 20, 2015 Share Posted March 20, 2015 What is FRP showing KOEO, and how quickly does is it build cranking? Quote Link to comment Share on other sites More sharing options...
RyanG Posted March 21, 2015 Author Share Posted March 21, 2015 FRP IS SHOWING .29-.30 VOLTS - 58 PSI KOEO. COMPARED TO ANOTHER TRUCK, IT IS SLIGHTLY SLOWER TO BUILD FRP. I DID NOTICE ISSUE IS MORE NOTICABLE WITH ENGINE WARM. RECHECKED TORQUE ON PCV. Quote Link to comment Share on other sites More sharing options...
Gustavo Posted March 22, 2015 Share Posted March 22, 2015 Last time I had a p0087 was because their was Small metal flakes in the high pressure fuel system. There was no visible metal flakes on the pcv or vcv. But when I took a sample from the left rail on the return line in a black cap I found the metal flakes. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 23, 2015 Share Posted March 23, 2015 I had one that had the PCV replaced at another dealer and would intermittently set P0087, All tests passed. Ended up replacing the entire left fuel rail and it hasn't set since. Something about a valve in the rail that can cause issues. Quote Link to comment Share on other sites More sharing options...
RyanG Posted March 23, 2015 Author Share Posted March 23, 2015 I'm going to remove return line again and recheck for metal and if I don't find anything I will replace the rail first before I condemn the pump. like I said I found nothing on the vcv, I would think if the system had metal in it I would see something. I did see other posts about the rail causing similar issues. Anyway I will throw one in and see what I find. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 23, 2015 Share Posted March 23, 2015 Just found out mine is coming back with MIL on. If it's a P0087 again I will post findings. Update: Was a reductant tank heater code. Retail. Quote Link to comment Share on other sites More sharing options...
RyanG Posted March 26, 2015 Author Share Posted March 26, 2015 Well it needs high pressure fuel system. Pulled return line off of the left rail and its full of metal. Its odd that nothing showed up on the pcv or vcv. I'm wondering if this is going to be the case with the cp4 pumps. Truck has extensive maintenance record, all ford filters its whole life and didn't find any evidence of contamination or rust. I did read somewhere that the cp4 is not as reliable as the cp3. Who knows. Thanks for everybody helpin out 1 Quote Link to comment Share on other sites More sharing options...
