Steve Mutter Posted March 20, 2015 Share Posted March 20, 2015 I have 2010 e350 6.0 that has an small oil leak at #8 exhaust port. I removed the up pipes and inspected the manifold and found it dry. I ran the engine and found no smoke coming from either bank. Has anyone seen a leak like this, they are complaining about oil consumption but I can't find anything. Back side of turbo and egr cooler is dry as a bone as well. I don't know if that oil leak means anything, any thoughts? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted March 20, 2015 Share Posted March 20, 2015 Possible rocker box gasket? I have seen those leak only on e-series. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted March 20, 2015 Author Share Posted March 20, 2015 I had a look at that and it is dry up top but wet on the bottom. Quote Link to comment Share on other sites More sharing options...
lmorris Posted March 20, 2015 Share Posted March 20, 2015 It could just be condensation mixing with the soot and looks like oil but isn't. I have seen a few like this. Most have loose exhaust manifold bolts when I see this. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted March 24, 2015 Author Share Posted March 24, 2015 It must be, I cleaned it up and will re inspect the truck later on. I am going to start an oil consumption test and see if this thing is really losing oil. Quote Link to comment Share on other sites More sharing options...
