Best place to get power for radio
Hey guys I am putting a business band radio in a 2006 f-350.  I am wondering where you guys are hooking into for power and ground. I am not a fan of fuse taps because they ruin the fuse panel. also not a fan of chopping into factory harnesses for such purposes.  Input greatly appreciated.
In the bundle of blunt cut customer access wires above the park brake pedal, there is a wh/bl wire that is 10 amp fused in run. I use this for all the plow installations. The only draw back on your setup is it's not hot in accessory.
  • Like 1
If I am looking in the right place this vehicle does not have a wire that color in this location. I am looking in the bundle with all the pto wiring and the 4(red, black, white, blue) upfitter wires above the park brake pedal.  The only white/LB wire I can find is taped off in the harness going to the data link connector with a customer access tag on it........... I don't really care if it is not powered in accessory as long as it is keyed power, preferably fused. Thanks for responding so quickly Brad
Excellent thanks Brad. I just wanted to make sure it wasn't something special in the network or some other crazy deal since it was in the harness and close to the data link connector.
