kellyf Posted April 28, 2015 Share Posted April 28, 2015 Anyone else have problems enrolling vcm generic tool?When I click the button it just turns yellow Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted April 28, 2015 Share Posted April 28, 2015 Generic vcm? Or the obdII compliant scanner for everything else? Quote Link to comment Share on other sites More sharing options...
kellyf Posted April 28, 2015 Author Share Posted April 28, 2015 the program Ford offers to make the ids generic. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted April 29, 2015 Share Posted April 29, 2015 Sorry bud, can't help you. Only played with it once or twice when it first came out. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 30, 2015 Share Posted April 30, 2015 I thought they took the website down when the VCM2 came out. Here's the site, the install link is still down: http://www.motorcraftservice.com/vdirs/wds/diagnosticsites/GOBDii/usen/ When I got my VCM2 I e-mailed IDS tech support to ask them about why/whether the generic OBD portion didn't work. They responded that there was no such thing. I sent them the link....... Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 26, 2015 Share Posted July 26, 2015 I've used it on mine. It doesn't do a whole lot but if you want to check monitors and clear codes and stuff it works OK. I haven't used it in a while. I have the installer for it on my PC if you want. If I recall rightly it just modifies a shortcut and adds a switch to the end of it. In your windows Run box, try this: "c:program files (x86)ford motor companyidsRuntimetestman.exe" /A=GEN_OBD2F The bolded part may differ on your PC, that's where I have it installed on mine. You must have the quotes in the "Run" window as they are in the line above - or it won't work. Alternatively you could open a command prompt window in that runtime folder and type "testman.exe /A=GEN_OBD2F" (without the quotes) Quote Link to comment Share on other sites More sharing options...
