Steve Mutter Posted May 8, 2015 Share Posted May 8, 2015 I just got my first updated turbo for that p259f code and found out there are some more parts you will need to get. First off you will need the gasket and bolts that goes in between the turbo and the pedestal as the new turbo does not come as one, O-rings and bolts for the oil feed and coolant lines and you will need a new coolant line as they have re located how it bolts down on the turbo. Just got caught off guard as all the other turbos for 6.7 have been drop in and go. This one will have to get pushed out side as that coolant line is not stocked in Canada. The 2015 upper intake is a bit more of a pain in the ass and the v-band clamps are harder to get at IMO. Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 8, 2015 Share Posted May 8, 2015 Steve, does the parts listing give any mention of needing additional parts? Has anyone checked PTS for any messages? This stuff is usually documented somewhere. Thanks for the heads up though. Will look into it when I get a chance. Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 8, 2015 Share Posted May 8, 2015 Edit isn't working so....By chance can the bolt flange be rotated? Parts shows no indications of any parts changes or the requirement to order additional parts for an updated turbo. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 8, 2015 Share Posted May 8, 2015 Forget notifications and listings. Again I find myself asking WHY Ford doesn't simply include the parts required to install the turbo in the box WITH the turbo. All that aside, thank you for posting this Steve. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted May 8, 2015 Author Share Posted May 8, 2015 No message about the coolant line, but the part number has been updated. It doesn't look like the flange can rotate I tried moving it with a little bit of force and it didn't budge. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted May 9, 2015 Share Posted May 9, 2015 It's about time they updated them cheesy fittings. I replace about 3 or 4 a week, it gets old quick. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 9, 2015 Share Posted May 9, 2015 I am glad to see the updated fittings as well. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted May 12, 2015 Author Share Posted May 12, 2015 I called(emailed) the hotline and they told me the updated turbo will need an updated coolant line, they gave me this part # fc3z-9u469-b. 1 Quote Link to comment Share on other sites More sharing options...
r-wats70 Posted May 17, 2015 Share Posted May 17, 2015 so happy I looked on here.....I have one to replace along with an engine in a remote spot up north... I will get that coolant line ordered before I have to go back up... thanks for the input Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 17, 2015 Share Posted May 17, 2015 Is this the 15 pickup turbo or are the cab and chassis turbos different too? I haven't worked on any 15s yet Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted May 18, 2015 Share Posted May 18, 2015 cab and chassis are carry over from 14 Quote Link to comment Share on other sites More sharing options...
Fordracer Posted May 18, 2015 Share Posted May 18, 2015 Now there's a TSB 15-0077 for this code and it has a parts list. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 18, 2015 Share Posted May 18, 2015 Wow, more turbo concerns? Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted May 19, 2015 Share Posted May 19, 2015 It is a Fomoco Diesel Core Value now. Part of the mission statement. I'm hoping they rewrite the mission statement and make radiators last longer than brake pads. 1 Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted June 19, 2015 Share Posted June 19, 2015 Could someone please clarify this for me?I have a 2015 F-350 cab and chassis here with a P257F like the TSB outlines(Ran oasis and the TSB applies). It appears to have the correct turbo for a cab and chassis truck. The part number the catalog lists is the BC3Z-6K682-B turbo, the TSB turbo is totally different.Are they having us actually change the style of turbo on these trucks or am I totally mistaken? edit - well I feel like an idiot. If I could actually read I would have known that the TSB only applies to pickup trucks. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted June 23, 2015 Share Posted June 23, 2015 Also this code only applies to pickups. Hotline tipped me off to that along with the p041B I got on the following road test. This 15 cab and chassis I had did infact have a pickup calibration in it from the factory. Put the right cal in it and all is well. They're surely going to be complaining of a lack of power now. This thing hauled ass the first time I drove it. Quote Link to comment Share on other sites More sharing options...
Chad_Kelsoe Posted July 26, 2015 Share Posted July 26, 2015 Anybody else doing any 15 model turbos? Been on the discussion boards and a lot of guys are complaining about these. Several guys even say they are pulling cabs to do them. I haven't done any personally, but I have no issues doing the 11-14 models. A air hammer and long punch works great through the fender well. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted July 26, 2015 Share Posted July 26, 2015 I have not done a 2015. What are guys bitchin about and why are they pulling cabs? The clamps are not the easiest to get to but certainly not impossible or worthy of pulling the cab. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 26, 2015 Share Posted July 26, 2015 Yeah I read all that the message boards also but I haven't done one myself. I guess we'll see Quote Link to comment Share on other sites More sharing options...
Fordracer Posted July 27, 2015 Share Posted July 27, 2015 I did one and they are a bitch.You have to pull the down pipe out of the cobra head (the elbow that bolts to the turbo) to get access to the bolt that goes in the block to support the head. I wrote the hotline and asked if I needed to pull the cab and they said the pipe should come right out. I finally got it apart with a lot of hammering but they are no fun. It's also harder to get to the intake manifold bolts. Quote Link to comment Share on other sites More sharing options...
lmorris Posted September 2, 2015 Share Posted September 2, 2015 Doing my first one now. First thing to note: remove the fuel filter and holder, remove the EPB sensor tube, rotate the upper intake clockwise until it clears the vapor seperator and it will come out fairly easy. Second thing: Loosen the Torca clamp and soak it down with penetrating fluid from the top, let it sit for 10-15 and mine slid right out. Didn't even have to remove the inner fender either. Was able to get to Cobra head bracket bolt from under the truck. Third thing: other than the slight weight increase, this was easier to remove than previous models. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 26, 2016 Share Posted April 26, 2016 Does anyone have the tsb 15-0077 saved for the parts list? I have a truck that has repeated setting the p259f after reprograming ppt ka leads to replace turbo. Quote Link to comment Share on other sites More sharing options...
