Jeff Clyde Posted May 11, 2015 Share Posted May 11, 2015 does anyone know if an 03 short block will work for an 06 truck ? Heads, branch tube, hpop etc would be transferred. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 12, 2015 Share Posted May 12, 2015 Probably yes. The only differences I can think of are the 03 pistons and cam are slightly different (but only for emissions reasons?)... and the upper oil pan has extra bolts holding it to the bedplate. I doubt any of this will matter as long as you use all the remaining stuff from the 06. I would swap in a new set of lifter guides at the very least. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted May 12, 2015 Share Posted May 12, 2015 Didn't the 03-04 combustion chamber change, which is what made the pistons different? Are the heads the same? I know the GPs are different. Quote Link to comment Share on other sites More sharing options...
Jeff Clyde Posted May 12, 2015 Author Share Posted May 12, 2015 The newer model glow plugs are 1mm (iirc), to prevent contact with the change in bowl design of the piston. 18mm heads are the same I believe, but do remember a camshaft difference. Quote Link to comment Share on other sites More sharing options...
