Keith Browning Posted May 16, 2015 Share Posted May 16, 2015 For the front 4X4 shaft axle shaft snap rings - those rings are pretty stout! What is the best set of pliers? Or better yet, if you have an awesome set that works really well, what brand and what is the tool number? I broke my old Snap-On pliers some time ago but I struggled with them mostly because they were not necessarily the right size for the application. Since money has been tight I have been borrowing pliers from several guys. I can buy a set now and having tried a few am sure I like the Knipex best as they seem to require less effort. Cant figure out the tool number though. What say you? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 16, 2015 Share Posted May 16, 2015 I use snap-on SRPC9000A. Slightly difficult to use but it's the only thing I've seen that works 1 Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted May 16, 2015 Share Posted May 16, 2015 I take these http://buy1.snapon.com/catalog/item.asp?search=true&item_ID=647705&PartNo=SRP2&group_id=676033&supersede=&store=snapon-store&tool=all and spread that snap ring a couple of times to make that snap ring submit :hammer: .... then use my snap ring pliers to remove it. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 16, 2015 Author Share Posted May 16, 2015 I have used those and the Knipex. The Snap-On set in the pic does work though but I have trouble using them and the Knipex seemed much easier to spread the rings. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 16, 2015 Share Posted May 16, 2015 The knipex look interesting. I found a 7" or 9" set that could possibly work, do you remember about how long the pliers were? 1 Quote Link to comment Share on other sites More sharing options...
Chad_Kelsoe Posted May 16, 2015 Share Posted May 16, 2015 A coworker has a set of MATCO snap ring pliers that I use. The exact one I use on those snap rings is a MST5602. The kit is MST1225. 1 Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted May 18, 2015 Share Posted May 18, 2015 I use the one that Matt posted. But you have one way that it has to be to get the ring off. One of my co-workers struggled for better than a half hour with one on a 12 f250 the other day. Too stubborn to ask for help. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted May 18, 2015 Share Posted May 18, 2015 I have the Knipex. Best pliers I've ever used for those snap rings. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 18, 2015 Author Share Posted May 18, 2015 I have the Knipex. Best pliers I've ever used for those snap rings.Tool/model number? Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted May 18, 2015 Share Posted May 18, 2015 I use the Snap-On ones that Matt posted above. they are the only things I have seen that work but they are still a pain in the ass. because they are short and the snap ring is so tough, it is difficult to squeeze the pliers enough to have the ring open up to the point in which it will slide off of the axle nose. most of the time I end up having the pliers slip (not able to compress the pliers enough to open the ring) and then I slam/pinch my hands together and get very frustrated. its much easier to put the snap ring back on the axle as I put a flat blade screwdriver against my chest (opposite end against the snap ring) and while opening the snap ring with the snap ring pliers I push my chest/screw driver into the hub which helps get the snap ring to jump into the grove. like I said this is the best I have seen at being able to take off the snap ring/ put on the snap ring...if there is a better option out there I would love to have it Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted May 18, 2015 Share Posted May 18, 2015 I don't know the number off hand. I'll post it when I get to work tomorrow. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 18, 2015 Share Posted May 18, 2015 I put the snap ring on the same way Chris does. Getting it off is tricky. I'm open for any better options out there Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted May 19, 2015 Share Posted May 19, 2015 I struggled with the first ones i did when they came out then I bought the knipex one. Mine was from matco the part number is worn off the handle but its in this set. matco set # SPRIE8 Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted May 19, 2015 Share Posted May 19, 2015 These are the pliers. They are 9" Knipex I bought from Matco. There is no model number on them. They NEVER slip. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted June 2, 2015 Share Posted June 2, 2015 Could you spread the ring enough to get these in? http://www.ebay.com/itm/Wilde-Tool-10-in-Straight-Compound-Lock-Ring-Pliers-Snap-Retaining-MADE-IN-USA-/131155893946?cmd=ViewItem&hash=item1e89801eba&pt=LH_DefaultDomain_0 Quote Link to comment Share on other sites More sharing options...
ktmlew Posted June 2, 2015 Share Posted June 2, 2015 http://www.amazon.com/GearWrench-2012D-Combination-Heavy-Pliers/dp/B000RH3882 Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 3, 2015 Share Posted June 3, 2015 Pretty sure they are Blue Point. Had them for so long the name and part number are worn off. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted June 17, 2015 Share Posted June 17, 2015 Blue Point PR52. 9.5" long, Locking, and replaceable tips. Several different tip styles available as well, although I use them strictly for these clips. I got tired of breaking the tips off my snapon SRPC9000A pliars and having to wait for warranty all the time. Have yet to break the PR52s. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted June 18, 2015 Share Posted June 18, 2015 Those pliers look bad ass Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted July 15, 2015 Share Posted July 15, 2015 I took the recommendation Chris made but I chose to pruchase the Proto 361 for about $40 less the the Bluepoint one's. I am pretty sure the Bluepoint one's are just reboxed Proto and my Snap-on rep said the tips are not warrantied. That's a brand new snap ring from a hub seal kit. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted July 15, 2015 Share Posted July 15, 2015 Yep those sure look like mine, although mine are blue. Quote Link to comment Share on other sites More sharing options...
batmantech Posted July 15, 2015 Share Posted July 15, 2015 Glen nice bench, is that thing brand new? Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted July 16, 2015 Share Posted July 16, 2015 Glen nice bench, is that thing brand new?Yes it is new https://www.sevilleclassics.com/rolling_cabinet_drawers_ultra_hd and I'm actually not done putting it together. It's going to go underneath workbench that I'm having made. When I get inside of my shop done I'll probably post some pics. I was able to put up a new shop almost 3 years ago and there's still some small stuff that needs to be finished. Quote Link to comment Share on other sites More sharing options...
batmantech Posted July 29, 2015 Share Posted July 29, 2015 blue point PR-56A Quote Link to comment Share on other sites More sharing options...
