Sync troubles
This morning my sync stopped working in my 150. Currently have no Bluetooth, no aux function or voice commands. If I tap aux button the screen flashes aux for a second then goes right into fm function. I've been away from the dealership for 4 years now and am disconeceted from software updates and Ids awesomeness. My question is: is there an update for software in the sync system or anything else to help me diagnose this? More info 09 150, no nav, no satellite. Thanks guys.
Did you try updating from syncmyride.com? More then likely it sounds like you APIM has gone tits up. There may be extended coverage on your APIM, but you'll have to contact a dealership to verify.
I havnt done any real diag as of yet.  Happened on my way to work and havent had time to troubleshoot. I'll look into syncmyride for sure. 1FTPW14V79FB31588 is my vin Brad. Thanks guys
No extended coverage, but here is your info and history:
OASIS RESULT: 1FTPW14V79FB31588 USA: EN-US 26-MAY-2015 / 21:05:02 EST/ EDCAS041BLocal Time: 26-MAY-2015 / 9:05:05 PMVEHICLE INFORMATIONAdditional InformationVEHICLE DESCRIPTION: 2009 F-SERIES LD Version/Series: 150 SERIES PAINT COLOR: Red Candy Tint CCBODY STYLE: DOUBLE CAB (CREW CAB) Drive Type: 4 WHL L/H PART TIME DRIVE PAINT CODE: U6ENGINE: 5.4L 3V V8 AXLE RATIO: 3.31 Ratio GROSS VEHICLE WEIGHT: 7200 LB. GVWENGINE CALIBRATION: 9F615R0A AXLE CODE: 27 RADIO: With AM/FM CD PlayerTRANSMISSION: 6 Speed Automatic Trans (6R80) WHEEL SIZE: 18 X 7.5" Chrome Clad Wheel SYNC VERSION: V2 Gen1FLEX FUEL: Y TIRE: LT275/65R 18C A-T OWL VHR ACTIVATED: YWARNING MESSAGESVERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTYACCURATE REPAIR NOTIFICATIONSATTENTION TECHNICIANS AND SERVICE MANAGERS:4.6L 3V & 5.4L 3V KNOCKING NOISE WITH HOT ENGINE AT IDLE SPEED SEE 10-18-04FOR DTCS P2195 OR P2197 ON 3V ENGINE APPLICATIONS, SEE TSB 11-03-275.4L HOT ENGINE IDLE RATTLE NOISE, SEE TSB 14-0114GENERAL WARRANTY INFORMATIONNew Vehicle Base WarrantyWARRANTY START DATE: 31-JULY-2009 BUILD DATE: 27-MAY-2009 Release Date: 01-JUNE-2009SALE MILEAGE: 00101OUTSTANDING FIELD SERVICE ACTIONSNO CAMPAIGN MESSAGE(S) FOUNDEXTENDED COVERAGESNO ESP INFORMATION AVAILABLEWARRANTY REPAIR HISTORYNO RECENT REPAIR HISTORY ON VEHICLEClick Here for Full Warranty History| Report a Vehicle Concern | On-line 1878 |END OF OASIS REPORT FOR 1FTPW14V79FB31588
Detailed Vehicle SpecificationVIN 1FTPW14V79FB31588Vehicle Line T/F6 Market Derived Code FBody Cab T/BC Ver. Series T/AMDrive Type T/EPLT CD AF TRS CD T/C3 ENG CD T/WXProduction Date 27-MAY-09 Warranty Start Date 31-JUL-09Selling Dealer 111528 Selling Country USAAWS Claim Key Trx Code Time In Service Labor Hours Dealership DIST (Miles) Repair Date Prefix Base Suffix DocDetails 621151 2 2 .2 ROUNTREE FORD 1716 24-SEP-09 * NPF * 12365001Customer Comments CUSTOMER STATES WHEN STARTING TO DRIVE DOWN STEEP HILL IN GREENFIELD, HE TURNS OFF OVER DRIVE AND VEHICLE SHIFTS DOWN AND CUSTOMER COAST DOWN 2 3 OF THE HILL. AFTER 2 3 OF THE HILL THE RPMTech Comments VERIFIED CONCERN. FOUND TRANSMISSION OPERATING NORMALLY AT THIS TIME. TRANS IS SHIFTING DOWN TO MAINTAIN SPEED.Details 870472 2 5 .5 ROUNTREE FORD 5122 15-DEC-09 * 2552 * 12579101Customer Comments CUSTOMER STATES THERE IS A BURNING SMELL COMING FROM THE REAR LIKE SOMETHING IS HANGING UP. DIAGNOSE AND ADVISE.Tech Comments COULD NOT VERIFY CONCERN, TOOK TEMP READINGS OF REAR BRAKE ASSY. SEE RO. TOOK APART REAR PADS AND COMPRESSED CALIPERS. NO BINDING. LUBRICATED SLIDES AND TEST DROVE. STILL NO CONCERN, SMELL COULD BE WATER DRYING OFF HOT TAILPIPE IN WATERY ROAD CONDITIONS.Details 916841 2 6 .2 ROUNTREE FORD 6882 06-JAN-10 * 17603 * 12621003Customer Comments CUSTOMER STATES PASSENGER SIDE WASHER NOZZLE DOESN T HIT WINDSHIELD.Tech Comments WORK FINE AJUSTED ITDetails 921033 2 6 .2 ROUNTREE FORD 6882 06-JAN-10 * 17528 * 12621002Customer Comments CUSTOMER STATES WIPERS DONT CLEAR AS DESIGNED.Tech Comments SEEMS LIKE RUBBER HAS DRIED REPLACED BLADES CLEARS WELLDetails 1266792 2 9 .2 ROUNTREE FORD 10179 21-APR-10 * 16700 * 12871302Customer Comments CUSTOMER STATES ON NUMEROUS OCCASIONS HOOD HAS BECOME UNLATCHED WHEN DRIVING. DIAGNOSE AND ADVISE.Tech Comments COULD NOT VERIFY CONCERN. ADJUSTED AND LUBED LATCH.Details 1266791 2 9 .2 ROUNTREE FORD 10179 21-APR-10 * NPF * 12871303Customer Comments CUSTOMER STATES VERY INTERMITANTLY TRUCK WILL GET A BURNING CHEMICAL SMELL ON FIRST START UP. DIAGNOSE AND ADVISE.Tech Comments CKED ENTIRE TRUCK FOR LEAKS NONE WERE FOUND. CKED ALL FLUID LEVELS ALL ARE GOOD. FLUID CONDTION ID GOOD ASWELL. CKED ON EXHAUST SYSTEM FOR SIGNS OF BURNING OR MELTING MATTER. ALL OK. CKED OASIS FOR A TSB NOTHING FOUND ABOUT ANY SMELL.Details 2371461 E84 19 1.3 ROUNTREE FORD 20967 09-FEB-11 9L3Z 16611B08 CA 13597702Customer Comments C S DRIVERS SEAT BELT DOES NOT RETRACT WELL AND PASSENGER SIDE LOCKS UPTech Comments RETRACTOR ON DRIVERS SIDE IS WEAK NEEDS NEW BELT PASSENGER SIDE BELT ALSO FAILED INTERNALLY LOCKING UP TOO EASILY TECH 85 REMOVED OLD BELT UNIT INSTALLED NEW AND ALL . WORKS TO SPECDetails 2371460 E84 19 .3 ROUNTREE FORD 20967 09-FEB-11 4L3Z 16700 AB 13597703Customer Comments HOOD LATCH HAS POPPED OPEN SEVERAL TIMES WHILE DRIVINGTech Comments NEEDS HOOD LATCH VERIFIED CONCERN TRIED ADJUSTING CONCERN STILL PRESENT GOT REPLACED HOOD LATCH WORKS PROPERLYDetails 2375693 TAP1 19 0 ROUNTREE FORD 20967 09-FEB-11 * TAP1 * 13597706Customer Comments ENTER TOTAL TAP DAYSTech Comments 2 DAYS TAPS INVOICE 1339Details 3114035 11S15 25 .9 ROUNTREE FORD 26798 10-AUG-11 * * * 14034804Customer Comments 11S15 DOOR HANDLE RECALLTech Comments 11S15 RECALL COMPLETE INSTALLED RETAINERS 4 DOORDetails 3229612 E84 26 1.1 ROUNTREE FORD 26798 31-AUG-11 9L3Z 17757 B 14082701Customer Comments CUSTOMER STATES CHROME IS COMING OFF FRONT BUMPER. DIAGNOSE AND ADVISE.Tech Comments VERIFIED CONCERN. NEEDS NEW FRONT BUMPER. REPLACED FRONT BUMPERDetails 3599422 E84 29 .2 ROUNTREE FORD 30102 12-DEC-11 AL3Z 1504132 AA 14307702Customer Comments CLIP ON DRIVERSIDE SUNVISOR WILL NOT HOLDTech Comments REPLACED CLIP ON DRIVERS SUN VISER
