Matt Saunoras Posted May 27, 2015 Share Posted May 27, 2015 Got a high miles 6.4 here that seems to not be able to make desired exhaust back pressure at idle. Ran all the normal pp test KA diag and verified with KA8 that EBP is not high enough with the engine at 1500 rpm and VGT at 90%. Now at the start of all this I did have a bad EBP sensor and a small tear in the hot side lower cac boot. Those issues have been resolved along with a calibration update, EBP tube cleaning, VGT solenoid swapped with a known good one, MAP sensor removed and cleaned. I even devised an EGR block off plate to rule out the EGR valve not sealing all the way. No change with anything. Crankcase pressure is well in spec also. Air filter is clean, DPF pressures are good, tailpipe is clean as a whistle. Hotline thinks a high side compressor cover cleaning is in order and if that doesn't work then put turbos in it. Anyone ever ran across this? Low EBP at low engine speeds? Otherwise the truck runs fine, I'm not sure if it will even set a P2263 while driving but it won't clear a P1000 after 30+ miles. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 29, 2015 Author Share Posted May 29, 2015 Also if anyone cares I installed a 6.7L EBP sensor for testing purposes and it behaved exactly the same as the DPFE-7 sensor the 6.4L actually calls for (I installed the correct one later). I saved the 6.7 sensor from an early EBP tube leak. The only difference externally I could see was the 6.4 sensor has International engineering numbers stamped in it and the 6.7 sensor does not. Otherwise same sensor, probably same vendor. . Quote Link to comment Share on other sites More sharing options...
RyanG Posted May 29, 2015 Share Posted May 29, 2015 JUST DROPPED IN A BRAND NEW REMAN. GOT THE SAME CODE, PINPOINT TEST IS TELLING ME TO REPLACE TURBOS. GOTTA LOVE IT! Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted June 2, 2015 Share Posted June 2, 2015 I got the same code (not lol) Quote Link to comment Share on other sites More sharing options...
mchan68 Posted June 2, 2015 Share Posted June 2, 2015 I just had a guy driving an '08 F-550 onto my doorstep complaining of a "SERIOUS lack of power". It set a P2263 KOER as well. Pulled the hood open, and hot side CAC hose was ruptured. Quote Link to comment Share on other sites More sharing options...
amailloux Posted July 22, 2015 Share Posted July 22, 2015 So I have 1 here now. 55k miles. sets 2263. ebp koeo good. wiggle the hell out of the connector with no change. test drive and desired and actual ebp are right on. customers complaint is smoke. now I know I have a cracked dpf due to the smoke. He runs a fucking Edge programmed and an aftermarket air filter as well. Maf reads 42 or so at idle which seems high. cleaned sensor with no change. The smoke may be normal for a cracked dpf, but still cant get 2263 to pass. #3 stft is -7 to -8. oil level is not overfull. The 1 thing I Notice is the egr closed voltage is 1.17 to 1.18. I believe it should be closer to 1 volt. We know how easily the valves come out to inspect for sticking slightly open so I haven't physically checked it. I can see it start to build boost on the koer test, but failes with 2263. No CAC leaks, no excessive crankcase pressure. last regen complete was 525 miles ago and pid is clean. I want a factory airbox and a dpf, but I sure don't want to start plugging the new filter. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted July 23, 2015 Share Posted July 23, 2015 I have an 09 f-350 dually ( a friends truck) that is setting this code. It will only do it pulling his trailer (39' toy hauler) up a large hill. It pulls like mad (has an h&s tuner and full delete exhaust) and then all of a sudden it de-rates and falls on its head. I went out the other night with him with an IDS connected, we pulled his trailer up the same 8% 4km long hill 3 times. Of the 3 pulls it only de-rated once. The strange think is no pids looked out of range anywhere. The only thing I can see is that VGT was at a very low %, around 5% I think, mgp was 36 ish, all temps were good. Every time I have ever scanned this thing it had no codes, except right after it de-rated, I pulled cmdtcs and p2263 came up. Im thinking a sticking vgt, but have never watched pids on a 6.4l pulling that hard. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 23, 2015 Author Share Posted July 23, 2015 The way I see it is with VGT so low the PCM wants to dump exhaust back pressure. It may be setting that code because it knows how close it is to being out of control of the VGT. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted July 24, 2015 Share Posted July 24, 2015 Stupid thing is, the only pid I forgot to record is ebp. DOH. Quote Link to comment Share on other sites More sharing options...
