lmorris Posted June 3, 2015 Share Posted June 3, 2015 Had these made up awhile ago. Finally get to use them. Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 3, 2015 Author Share Posted June 3, 2015 Here Are the pictures. Didn't work in original post. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted June 3, 2015 Share Posted June 3, 2015 You just balance it on one arm on each side? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted June 3, 2015 Share Posted June 3, 2015 Bitchin'!!! Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted June 4, 2015 Share Posted June 4, 2015 How much did they cost? That is quite possibly the greatest thing I've seen.... or may be at least this year Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 4, 2015 Author Share Posted June 4, 2015 They cost us about $300. We have a guy here who has a friend that owns a machine shop, so it was mostly the cost of the metal, supplies, and a bit of labor. I strapped the rear of the brackets to both door strickers and for safety I strapped the cab to the frame once it was up. I would have liked the pins off center to counter the slight tilt, but the builder didn't think it was a good idea. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted June 4, 2015 Share Posted June 4, 2015 I'm wondering if a set of current screw type rack adapters could be modified to work but with those you'd have a little adjustability. No hassle except the cutting and welding. I am going to see if you can buy them separately. Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 4, 2015 Author Share Posted June 4, 2015 The owner is going to talk to the builder to see if we can get another set of pins welded on in a better position to get the cab to sit more level. Will update with the answer. Quote Link to comment Share on other sites More sharing options...
exmod110 Posted June 4, 2015 Share Posted June 4, 2015 How about getting the pins set in an adjustable track or something so you can lift multiple cab cofigurations? super crews will have a diff center of gravity form a reg cab etc.... Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted June 5, 2015 Share Posted June 5, 2015 That's cool man! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 5, 2015 Share Posted June 5, 2015 My new coworker of mine built a set of these. As impressed as I was with this, I was equally leery about it. That is a lot of weight to have teetering on two points. Definitely trick though! Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 5, 2015 Author Share Posted June 5, 2015 I gave it a good rocking when it was about 6 inches off the front mounts, I was happy with the stability, Would prefer to have 4 points, but sometimes that's not an option. If the pins were aligned with the cab's center of gravity it would lift more level. Truck is done and out the door now so it was a success. Was doing an oil cooler BTW. Quote Link to comment Share on other sites More sharing options...
