Pentagon Allen
All of the gm sensors I have seen are hex. I will say that if the hub is aftermarket, sometimes a oem sensor will not have the correct air gap and will cause false activation. I have seen some with shims also. If in doubt, I sell a hub. We had a lazy guy that would unbolt the sensor from the hub, throw the new sensor away and bolt the old sensor into the new hub so he didnt have to get to the electrical connector. That seemed to cause a lot of problems in the 2 months he worked here.
I've run cross those in some places. MAF sensors on some Euro brands use pentagon and some have 5 point version of torx.
