Where Is The BARO Sensor?
Attempting to diagnose a 2006 LCF with an active 152 code. Pinpoint test H2 has you access and disconnect the BAP sensor connector C2256 and test the circuits. Okay. So I look at the location page in the EVTM - shows the sensor mounted on a bracket @ the center of the dash. I found the bracket. No sensor. No wiring. I have pulled off more trim, the IC, radio and so on looking for it. In later model years the BARO sensor is integrated into the PCM. So I had to defer to the experts on the product...
Meanwhile, the Hot-Line has been working on this one for more than 5 hours now.
