RyanG Posted July 1, 2015 Share Posted July 1, 2015 Not sure if this has been posted before, was wondering what kind of labor times for complete fuel system replacement. Truck came in with p0088, reprogrammed and now its back 2 months later with same code. Took fuel sample from injector supply tube and found metal flake. This is my first one and not sure on how much labor. Quote Link to comment Share on other sites More sharing options...
Chad_Kelsoe Posted July 1, 2015 Share Posted July 1, 2015 I get roughly 28 hours to do a fuel system. Make sure you use everything the fuel system job aid tells you to replace. We use to clean the secondary filter housings out if they just had metal, no rust. Then I had a high pressure pump fail within 1000 miles, Ford kicked it back saying since I didn't replace the housing I introduced metal back into the system. That time includes pulling the cab, flushing the heads and low pressure lines, and removing the fuel tank and cleaning a plastic tank or have a metal tank sent off, cleaned, and relined. Quote Link to comment Share on other sites More sharing options...
RyanG Posted July 1, 2015 Author Share Posted July 1, 2015 I quoted the guy 27 to do everything. Right now its looking like im gonna be buttoning it back up and have a nice day. I didn't see much in the fuel bowl either but when ahead and quoted it anyway. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 2, 2015 Share Posted July 2, 2015 I quote the high pressure pump, all injectors, both rails, FRP sensor (which is not reusable ever), secondary fuel filter housing, and both low pressure lines going to the HPFP. I will take the frame rail pump to the bench and clean it all out along with whatever tank is on the truck. Now is a good time to have a look at all the other stuff on the engine too, belt tensioner, coolant leaks, exhaust manifolds, etc that are real easy to fix with the cab up. Same goes for inspecting the rocker arms. I've been doing 25 hours lately. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted March 18, 2016 Share Posted March 18, 2016 What line is the "Fuel Supply Line" that is listed in the parts list in the water in fuel job aid? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted March 18, 2016 Share Posted March 18, 2016 That is the line that goes from the secondary fuel filter housing to the high pressure pump, it runs under the right side of the low pressure turbo. 8C3Z-9C330-B is the number On retail jobs I also quote 8C3Z-9B337-A which contains a check valve for the HPFP return side. I don't believe the job aid has you changing this but I do. 1 Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted March 19, 2016 Share Posted March 19, 2016 That is the line that goes from the secondary fuel filter housing to the high pressure pump, it runs under the right side of the low pressure turbo. 8C3Z-9C330-B is the number On retail jobs I also quote 8C3Z-9B337-A which contains a check valve for the HPFP return side. I don't believe the job aid has you changing this but I do. Excellent. That was what I was guessing, but I wasn't sure. Thank you. Quote Link to comment Share on other sites More sharing options...
