the_twig_187 Posted September 18, 2015 Share Posted September 18, 2015 this trend is starting to scare me a little bit. I have a 2015 F-550 with a 6.8L V10 with 28,000 km. there was a very loud tapping noise from the left cylinder head that got much worse when the vehicle was hot. I removed the valve cover and found the cylinder #9 intake rocker/roller arm bearing had completely seized and dragged the cam lobe across it. The best part about the job was the fact that this is a U-Haul vehicle and they have modified it and put a ramp on top, to use as a mini car carrier. this ment that I could NOT cab off to perform this procedure and that I had to pull the engine out the front in order to replace the cylinder head. The fun didn't stop there tho, because the car carrier brace was through the front bumper we could not remove either of them. With both of those in place it left me about 3 feet short with the engine crane to be able to hook onto the lifting bracket. thus, off to the machine shop to get an 8 foot long beam to use as a make-shift engine crane extension boom. Got the job done but it was a major pain in the ass... have seen two cylinder head component failures on brand new vehicle in the last month. anyone else seeing these? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted September 19, 2015 Share Posted September 19, 2015 I haven't seen an engine failure like that in a Super Duty but I went through a 2-year streak of V-10 engine failures. Things have been fairly quiet lately in that respect. The truck is a U-Haul service truck used to do light repairs and shuttle car dollies and small trailers around. I have three that visit me regularly with 6.7L engines. Quote Link to comment Share on other sites More sharing options...
amailloux Posted September 19, 2015 Share Posted September 19, 2015 What part of the head was damaged? was the valve loose in the guide. I did a cam and followers in a high milage 5.4 for a friend last year and it is still pumping away. Quote Link to comment Share on other sites More sharing options...
the_twig_187 Posted September 19, 2015 Author Share Posted September 19, 2015 the cam bearing caps at the #9 and 10 cylinders were scored so I had to replace the head Quote Link to comment Share on other sites More sharing options...
DieselD Posted September 21, 2015 Share Posted September 21, 2015 no words of advice other then I know all too well how bad those uhaul trucks suck to work on! I worked on them way too often with the 6.4 engines! Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted September 21, 2015 Share Posted September 21, 2015 U-Haul, baby! Quote Link to comment Share on other sites More sharing options...
