mchan68 Posted October 30, 2015 Share Posted October 30, 2015 Just playing around looking up commonly failing parts I noticed 6.7L rads have now changed up part numbers from BC3Z-8005-E to BC3Z-8005-G. Does anyone know if these rads are in fact updated in some way to prevent repeat failures, or is this something I'm going to have to look forward to, as a regular maintenance replacement being the owner of one myself? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted October 31, 2015 Share Posted October 31, 2015 Looks like G is about $30 cheaper cost. What's weird is this remark when you search BC3Z-8005-G in DOW. PENDING OBSOLETE, NEW LEVEL BC3Z8005K IN TRANSIT YET. That message was from 2 days ago. Its showing K's in transit to some depots. Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted October 31, 2015 Share Posted October 31, 2015 I wonder if they have a found way to make the end tanks out of rubber? Quote Link to comment Share on other sites More sharing options...
nelsona19 Posted November 2, 2015 Share Posted November 2, 2015 If I had a leaky 6.7L, I'd look into a new Mishimoto myself. www.mishimoto.com/ford-6-7l-powerstroke-aluminum-radiator-11.html Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 2, 2015 Author Share Posted November 2, 2015 YOWZERS!!!! At $1050 US, they sure are proud of their product. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 2, 2015 Share Posted November 2, 2015 I really want to know how they can justify the price on things like this. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 3, 2015 Share Posted November 3, 2015 If I am not mistaken, Aaron put one of them in his 6.4 and it still sprung a leak like the Ford units. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted November 3, 2015 Author Share Posted November 3, 2015 If I am not mistaken, Aaron put one of them in his 6.4 and it still sprung a leak like the Ford units. I was just going to say that. And he's far from the only one from what I read. I am actually quite baffled as to why Ford hasn't figured out what's causing these failures with the number of years they've been in production. Quote Link to comment Share on other sites More sharing options...
amailloux Posted November 3, 2015 Share Posted November 3, 2015 It seems like the core fractures and leaks, NOT the side tanks or side tank gaskets. They crack usually about 8 inches down where the cross tubes meet the aluminum end plate. And yes the Mishi's leak as well and crack in the same place. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted November 4, 2015 Share Posted November 4, 2015 Haha you mean like this one I did today Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted November 4, 2015 Share Posted November 4, 2015 It is hard to ignore the core support torquing the radiator as something that needs to be investigated. 6.4 and 6.7 share that design and mount and kill radiators in similar fashion. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted November 4, 2015 Share Posted November 4, 2015 Yep, you can make a brand new one leak by lifting the front corner of the truck with a floor jack, let it back down and it will seal back up. Quote Link to comment Share on other sites More sharing options...
DieselD Posted November 13, 2015 Share Posted November 13, 2015 so far I have yet to change a 6.7 radiator. lots of 6.0s and 6.4s but yet to change one on our fleet of 6.7s my personal 6.7 has 118k on it and Ive had engine oil leaks(upper pan) and transmission(torque converter) leak but no coolant yet. Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 22, 2015 Share Posted November 22, 2015 Mishmoto ones are junk and their warranty sucks balls to deal with. I've got a 2yr/unlimited FoMoCo one in it now. (Which has failed once already since May of this year) I've changed the body mount isolators, hogged out the upper radiator mounts to allow it to move around. We'll see what happens. I also dropped to a 10psi cap. Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 16, 2016 Share Posted May 16, 2016 Put in two of the new "K" radiators. I noticed something odd about them. Nothing on PTS or in WSM. Asked Hotline and waiting for reply. Quote Link to comment Share on other sites More sharing options...
Chad_Kelsoe Posted May 16, 2016 Share Posted May 16, 2016 We've put in 5 or so over the last few weeks that were also like that. I just drill the hole out and use the clip from the old radiator. Quote Link to comment Share on other sites More sharing options...
RyanG Posted May 16, 2016 Share Posted May 16, 2016 Same here. Drilled a hole and put the clip on Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 16, 2016 Share Posted May 16, 2016 Same here. Drilled a hole and put the clip on Was going to do that, then I also noticed the slot for the clip is not cast the same either. Hotline said there has been no parts change info sent out. I left it as is. There is no slop in the fit up in that corner anyways. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 16, 2016 Author Share Posted May 16, 2016 The part number has changed up yet again, this time to Motorcraft part number RAD-61. Almost seems like they can't stop updating it. On a different note, has anyone else ever had a repeat rad failure on a 6.7 yet? I know there have been numerous repeat failures on 6.4 trucks, but I don't think I've heard of any on a 6.7 truck yet. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 16, 2016 Share Posted May 16, 2016 No repeat failures that I can remember. The K radiator I just put in was missing that hole drilled too. Drilled it and reused an old clip Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted May 27, 2016 Share Posted May 27, 2016 I haven't seen all that many to begin with. Maybe three or four? Quote Link to comment Share on other sites More sharing options...
RyanG Posted May 31, 2016 Share Posted May 31, 2016 I've done between 5 and 10, only had one repeat so far. Quote Link to comment Share on other sites More sharing options...
