Jeff_ Posted December 10, 2015 Share Posted December 10, 2015 Anybody have a brand and part number for one, I've been searching with no luck. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
JoeR Posted December 11, 2015 Share Posted December 11, 2015 Sonnax makes a slightly oversized pump bushing to cure loose fit of the converter hub. You need to do the final fit on your own. Is this what you're looking for? http://www.sonnax.com/parts/2048-pump-bushing If so, I get almost all my Sonnax stuff from Transtar. Joe Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted December 11, 2015 Share Posted December 11, 2015 That's cool, I used to ride by this place on my to work everyday. It's a small little joint and a co-worker's wife worked there also. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted December 11, 2015 Author Share Posted December 11, 2015 That bushing may not be a bad idea too, but i'm looking for something I can use to fix the actual torque converter which has a groove worn in it from the seal, I don't want to have a repeat seal failure. Quote Link to comment Share on other sites More sharing options...
Buddy_M Posted December 11, 2015 Share Posted December 11, 2015 Try a 99200 speedi sleeve from napa. I think hub diamater is 2.00" so that should be right number. Measure your hub and a good parts counterman should be able to reference it in their book if I'm wrong from memory. Repair sleeve numbers are quite easy too, the last 3 in the part number denotes approx shaft size it fits. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted December 11, 2015 Author Share Posted December 11, 2015 Thank you! Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted December 11, 2015 Share Posted December 11, 2015 SKF-Speedi-Sleeve.Sizepdf.pdf Quote Link to comment Share on other sites More sharing options...
