lmorris Posted June 21, 2016 Share Posted June 21, 2016 I no longer talk to customers on the phone and this is why. If they don't have enough understanding of their truck to access the situation and come to their own conclusion as to whether or not they should tow it in to us, then why do they think they are going to understand my questions and give me an informed answer so I can make an informed conclusion as to whether they should tow it or not. Quote Link to comment Share on other sites More sharing options...
Fredsvt Posted June 21, 2016 Share Posted June 21, 2016 Oh why, why do stupid Ambulance companies with wheelchair lift vans buy stripper model E vans, with no factory rear air, then have craptermarket shyte put in. Have a 2008, no a/c, found leak in front, fixed. Evac, charge with 4 lbs as indicated on aftermarket sticker. Rear unit proceeds to blow, filling damn van with vapor cloud so thick you couldn't see inside. Now, to get to it, looks like whole left side interior comes off, all once piece of crummy, Yugo grade, floor to ceiling plastic has to come off as well as a ton of other stuff. Not even a though to service access. Rant over Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted June 23, 2016 Share Posted June 23, 2016 Why....... I took more time & energy to return the truck to proper wiring & then to diagnose the original problem. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted June 23, 2016 Share Posted June 23, 2016 Note to self... when you shear a radius arm off by hand while trying to remove the nut just go home I didn't.... instead I tried to recover by running an Expedition in & trying to bang out a set of lower ball joints.....Key word is "Bang" if you can't hammer the lowers out just stop & get a complete arm coming. I cut the flange off so I could get enough force on it to press it out, well too much of the aluminum came with, then I had 2 vehicles waiting on parts & the OE arm was in Detroit (Well customer opted to go with an AM lower control arm)On a side note the purple fuse in the pic is from my house HVAC, first hot day the A/C would not work, the control wires going to the compressor were bare @ shorting out on the air handler case. Found the problem before the residential HVAC guy called me back so.... Quote Link to comment Share on other sites More sharing options...
lmorris Posted June 27, 2016 Share Posted June 27, 2016 The number one thing taught by Ford technical training is how to navigate the Service manuals and follow PPT, yet I still keep seeing posts like this..... Working on a 2013 Super Duty, 135,xxx on the odometer. Has been having constant 4x4 problems. Can't seem to get the big hub seals to maintain a seal. R.F. has had wheel bearing replaced, knuckle replaced, hub seal replaced, and it still is leaking. Any ideas? Thanks Despite the urge to not respond, I had to.... WSM section 308-07A. There are tools to isolate the source of the leak. Start at PPT K26. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted July 2, 2016 Share Posted July 2, 2016 It took hotline 26 hours to respond to an assistance request. I sent it in at 2:30 on Thursday. I didn't get a response until 4:30 on Friday. But on the flip side I actually got some usable information from them. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted July 4, 2016 Share Posted July 4, 2016 Sometimes I get lucky.....When I noticed what was wrong with this picture I thought the brake job was done. Sometimes I think our job is not so much "Where Waldo" as it is what ALL did Waldo mess up. The red silicone used on the axle shaft to hub seal instead of an o-ring should have sent the alarms going off in my head. Here is the corrected pic Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted July 10, 2016 Share Posted July 10, 2016 Reason number 1 you should never try to hold on to any firework once it's lit. A comercial grade 3" mortor never left the tube. The side boards were hardwood and so was the floor board that has the hole in it. It threw the loaded tube next to it 50 yards into the field. Quote Link to comment Share on other sites More sharing options...
lmorris Posted July 18, 2016 Share Posted July 18, 2016 Disneyland ROCKS!! and being 47 years old, I never get tired of that place. What's even better is watching my daughter dance in Disney's Dance the Magic parade in both Disneyland and California Adventure. Super good time. Quote Link to comment Share on other sites More sharing options...
lmorris Posted July 19, 2016 Share Posted July 19, 2016 It's that time again.....Another PCM reprogramming recall on the 6.7L, another round of telling the same customers, for the 3rd time now, that they don't get the recall because they tuned their truck..... , I think I am going to start logging .2 for each one like this. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted July 20, 2016 Share Posted July 20, 2016 Whoops wrong thread 1 Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 19, 2016 Share Posted August 19, 2016 I must have lost my mind. I bought a 6.0 from another dealership with a blown up turbo. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted August 19, 2016 Share Posted August 19, 2016 Man I still have a lot of parts left over from my old 6.0. Do you need a turbo? Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 19, 2016 Share Posted August 19, 2016 Man I still have a lot of parts left over from my old 6.0. Do you need a turbo? A new one is somewhere around $900. I was just gonna drop a reman on it and be done with it. The turbo rattles when it runs. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted August 19, 2016 Share Posted August 19, 2016 There are brand new(not reman) Garrett turbos out there now the only issue is you have to order them from a distributor. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted August 20, 2016 Share Posted August 20, 2016 Hmm. I'm not keeping it so the reman will do just fine. Quote Link to comment Share on other sites More sharing options...
lmorris Posted August 30, 2016 Share Posted August 30, 2016 No matter how much you like the smell of the soap, never walk out of a public restroom smelling your fingers. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted September 4, 2016 Share Posted September 4, 2016 As of 8:15 this morning: This site has 1283 members of which 803 of them have never even made a single post. We have 24 members who have over 500 posts. We have 52 members who have over 200 posts. We have 75 members who have over 100 posts. The top 20 posters have a combined post count of 42,479 with an average post count of 2123.95 posts per person. 1 Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted September 4, 2016 Share Posted September 4, 2016 and I'm still chuckling about walking out of a public restroom smelling my fingers 'cause I'm guilty of doing that. Quote Link to comment Share on other sites More sharing options...
lmorris Posted September 6, 2016 Share Posted September 6, 2016 and I'm still chuckling about walking out of a public restroom smelling my fingers 'cause I'm guilty of doing that. Aren't we all though.. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted October 6, 2016 Share Posted October 6, 2016 One of the questions I get on occasion from customers that I would rather not answer is.."Do you think I can do X job myself/is it very hard"Based on the what I now know about the person that put these lug nuts on...The answer is easy... NO Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted October 6, 2016 Share Posted October 6, 2016 ever since you estimated that i could perform my own work i've had this funny vibration ... Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted November 4, 2016 Share Posted November 4, 2016 Had a guy with a duramax pull in off highway today. Fuel spraying all over from the HPP to LH fuel rail line at the rail. Had parts call chevy dealer (across the highway) closest line is in Greeen Bay WI. Guy says I will put electrical tape on it and drive it. Wow, that's high pressure fuel sparying on that hot engine. He then tells me he just had this engine installed. I said that looks to me like they tried to reuse a 1 time use line and it didn't work. I went back to work. Guy comes in little later tells me he has a line being overnighted to my dealer. And he is going to replace it himself in the parking lot. He had called his shop that put engine in, they reuse that line all the time. They also have to replace many of them leaking later. Its an easy job he says. Well at least he isn't trying to drive it. Quote Link to comment Share on other sites More sharing options...
lmorris Posted November 4, 2016 Share Posted November 4, 2016 Plastic pushpins and harness retainers are much nicer to work with when the engine only has 3 hours on it. Sadly...you can't remove the right head on a 2016 6.7L with the turbo in place...can't slide the exhaust manifold heat shield out between the manifold and turbo. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted November 18, 2016 Share Posted November 18, 2016 It is down right amazing the amount of vibration an incorrectly indexed dp6s clutch will create. And it was only off one hole. Quote Link to comment Share on other sites More sharing options...
