8WA Sman Posted December 1, 2016 Share Posted December 1, 2016 It is never a good idea to cut open empty drums.....This is what happened when someone was trying out their new plasma cutter & didn't take notice to the flame symbol on the side of that empty lacquer barrel. The barrel had some steel pieces sitting on top one piece got stuck in the ceiling. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted December 1, 2016 Share Posted December 1, 2016 Oh boy. Steel bars shot into the ceiling is impressive. It makes the garbage can I set on fire the other day look like a regular walk in the park! (I did a front cover reseal on a 3.7 in the morning. Somewhere around 9 am I cleaned the thing with brake cleaner over the garbage. At the end of the day around 4 or 5 I was cutting a rusted u-joint out of a prop shaft with the torches and shot some sparks over the top of the bench toward the can ... fun times!) Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted December 1, 2016 Share Posted December 1, 2016 A while back at a local shop a tech was trying to get antifreeze out of a drum using compressed air to start the siphon. The lid separated from the drum and killed him. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted December 3, 2016 Share Posted December 3, 2016 My dad has a drum deheader that works really well. But I've never cut a barrel that had extremely flamable stuff in it. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted December 4, 2016 Share Posted December 4, 2016 Yeah I did not post the pics until I knew the guy was going to be alright. It was amazing the size of the hole made by the plasma cutter was very small...I think that is what that mark is to the left of the lower plug. Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 14, 2016 Share Posted December 14, 2016 Over 25 years in the business and it still baffles me that customers bring in vehicles for driveabilty issues and the dash show 20 KM to empty. Quote Link to comment Share on other sites More sharing options...
batmantech Posted December 14, 2016 Share Posted December 14, 2016 That one drives me nuts. Last week no kidding had truck 0 miles to empty. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted December 15, 2016 Share Posted December 15, 2016 Expecting a tech to put fuel in a vehicle in order to work on it is like thinking the doctor should drive the ambulance. The 2 most commonly used tactics @ my shop when this occurs is...Customer you have just purchased some very expensive fuel or I will run it till it quits... you better show up with a gas jug Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted December 15, 2016 Share Posted December 15, 2016 Over 25 years in the business and it still baffles me that customers bring in vehicles for driveabilty issues and the dash show 20 KM to empty. Glad to see it's not just my customers Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted December 15, 2016 Share Posted December 15, 2016 Even though the engine comes with a crank sensor bolted onto the back of the block you are still expected to transfer the tone ring. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 19, 2016 Author Share Posted December 19, 2016 Over 25 years in the business and it still baffles me that customers bring in vehicles for driveabilty issues and the dash show 20 KM to empty. Unless the fuel tank has to come out then the damn thing is full! Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 20, 2016 Share Posted December 20, 2016 Oh yeah. My exhaust fluid fault light came on, so I filled it up. But the light didn't go out..... Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 20, 2016 Share Posted December 20, 2016 I get a lot of low def complaints when the customer tries to add a gallon and expects the message to clear. You wouldn't believe how many people make an appointment and never show up because once they finally listen to me and fill it up the message goes away in a few key cycles. I have only changed one heater/sending unit for an actual sending unit concern. Quote Link to comment Share on other sites More sharing options...
RyanG Posted December 20, 2016 Share Posted December 20, 2016 I run in to the same thing all the time. I have had 1 or 2 that would not reset after filling and had to do the refill activation procedure. Only had to replace one so far for a legitimate sending unit failure, I've probably replaced close to 20 for heater failures. Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 20, 2016 Share Posted December 20, 2016 Reading up on the service procedure to replaced catalytic converter on a 2013 Escape SE AWD 1.6L turbo.....Step 3:remove PTU if equipped....go over to PTU removal..step 2(before removing PTU)...Remove catalytic converter. I'm going to be caught in a WSM loop, what to do? And if that's not messed up enough..I was searching the web for said catalytic converter, Magna flow makes one for the 2L but not the 1.6L. You can get them on E-bay and Amazon, from US based Ford dealerships, for $587-$689 US....I just ordered one from my parts guy for...drum roll, $255 Canadian...WTF... Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 21, 2016 Share Posted December 21, 2016 My post was referencing every single time I have a def heater / sender replacement the customer fills the tank to try to make the fault go away.... Quote Link to comment Share on other sites More sharing options...
batmantech Posted December 21, 2016 Share Posted December 21, 2016 Observation---Automotive equations. New tech + Penetrating fluid+ Shop rag + Rusted wheel bearing + small butane torch = Large Fire Ball New tech + Detail shop tech + fire + Smart phone = Two guys watching fire ball and making video 1 Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted December 24, 2016 Share Posted December 24, 2016 Cheap people irritate me. Found this in the trailer tow power fuse on my dually this morning. And it was popped. Or at least it wasn't feeding power to my trailer. Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 28, 2016 Share Posted December 28, 2016 Another "Ever since you.." moment brought to you by the folks with the 2008 F350 6.4L that I replaced the fuel system on over 5000 KM's ago. "We just spent $9000 on this truck and it has an oil leak from the front cover" Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted December 28, 2016 Share Posted December 28, 2016 For which the correct reply is, "Bless your heart" Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 30, 2016 Share Posted December 30, 2016 The part of my brain that's supposed to remember to disconnect the suppression strap on a 6.0 right head before cab removal is missing. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 30, 2016 Share Posted December 30, 2016 The part of my brain that's supposed to remember to disconnect the suppression strap on a 6.0 right head before cab removal is missing. Nothing that solder and shrink wrap won't fix. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 30, 2016 Share Posted December 30, 2016 There's more than a few I've put out there just like that Quote Link to comment Share on other sites More sharing options...
lmorris Posted December 30, 2016 Share Posted December 30, 2016 The part of my brain that's supposed to remember to disconnect the suppression strap on a 6.0 right head before cab removal is missing. Nothing that solder and shrink wrap won't fix. Been there! Including a few of the under side frame to cab ones. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted January 4, 2017 Share Posted January 4, 2017 It's never a good feeling when a 6.0 is starting to suck air cause it's almost out of fuel. It's even worse when it's your own truck and you are 5 miles away from the nearest fuel station. 1 Quote Link to comment Share on other sites More sharing options...
