Glow Plug Failure
I had a '99 7.3 that had all glow plugs ohming out in the k ohms. I pulled the bank 2 valve cover and glow plugs and the glow plugs all still ohm in the k ohm scale. Originally I thought glow plugs did not look damaged but on closer inspection and research I noticed some of the tips do have something going on.
According to this http://www.beru.com/download/produkte/TI04_en.pdf the vehicle may have an in-cylinder issue.
The vehicle had no codes and the alternator checked out OK. I replaced the both UVCH when I did the glow plugs(not because they were bad but because they were old and brittle) not replacing them would have been a bad idea IMO. I also replaced the valve cover gaskets. The new glow plugs had an amp draw of right around 20 amps each. I was in a little bit of a rush the other week when the vehicle was in. It came back Fri. with a bad alternator and the battery bolts need to be replaced, should have that stuff done tomorrow and will recheck everything then.
I probably did not make a new post originally because I keep thinking these 7.3 are going away but they keep coming in. :ford:
Here is Keith's response to the original post http://www.forddoctorsdts.com/topic/5920-whats-in-your-bay-part-vi/?p=58621
And JoeR http://www.forddoctorsdts.com/topic/5920-whats-in-your-bay-part-vi/?p=58622
