Matt Saunoras Posted February 15, 2016 Share Posted February 15, 2016 Hey I've got an 08 E-350 cutaway here that has a leaking 37 gallon factory aft axle tank. I had the customer call Titan and they said their replacement 40 gallon will not fit and it was not designed for the eseries cutaways. Has anyone ever put a Titan tank on an eseries? They make a 40 gal tank specially for the PS-191 sending unit but I can't imagine what it would fit if it doesn't fit a cutaway. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted February 15, 2016 Author Share Posted February 15, 2016 Okay I got a little lesson in fuel tanks today and now I probably forgot something useful. The E-350 cutaway came with a 37 gal tank or an optional 55 gal tank. The 37 has 2 straps, the 55 has 3. That's the quick ID. The E-450 has a 55 gal standard. The 55 gallon tank is 6" longer, on my particular van the 55 would not fit due to the location of the last crossmember and the rear axle. The F-series has the 40 gallon tank that Titan sells, it is not the same shape and does not bolt in the same way as an E-series. Maybe some older E-series take this tank, I'm not sure. This is the tank that is supported by the large metal shield. Titan says the 37 gallon tanks aren't that common so they don't make a replacement.....And what is the only E-series tank we've ever sold? you guessed it, 37 gallon. Quote Link to comment Share on other sites More sharing options...
