Replacement nipples #%*!
jimmy57
I think I have an invention I need to develop: replacement brass nipples with self tapping threads for stupid plastic shit made these days. 3/16, 1/4, 3/8, 1/2 and other sizes with small hollow threads.
radiator
MAP sensor
plastic intake
tank leakage pumps
tank sending unit
probably a bunch of other things
The sheet metal screw threads would be no bigger, and in some cases, smaller than the nipple OD.
Just yesterday I broke a MAP/Boost sensor nipple on a 7.3 because I decided the hardened rubber hose should be replaced. In spite of cutting through hose with utility knife to avoid just such a problem.
The repairs on truck were for A/C.... No good deed goes unpunished..........
I think I may go do a mock-up. Take a brass wood screw, the ones with threads for 1/2 inch and then 3/4 or so of plain shank, and cut the head off and then drill through the length of screw. I can fix the old one and have it as a spare if this happens again (when it happens again).
