07 duramax turbo
They are a pain on the LMM transmission has to come out cause of a coolant tube runs directly over the turbo. If its a LBZ still bad but you can get it out just gotta go the pass. side wheel well to get the pipes loose. Need several 12mm 12 point sockets for all the pipes but the down pipe.
cab lift or partial cab lift was mentioned to me about these from a GM tech long time ago. but that would have been an earlier Dmax though.
Have fun with the wiring, GM does not know how to make bulkhead connectors or any connector. If you need any parts after you get in there be prepared to wait a couple of days.
what is the vin number of the engine. I'd assume its a LMM. 07 is a split year for new and old body. lifting the cab is the easiest way for these.
quick list of the top of my head: exhaust gaskets for the exhaust manifold to turbo pipes (4 gaskets total); egr valve cooler gasket; t/c oil line washers (x2); oil return pipe gaskets (x2) at the flywheel housing and turbo; t/b coolant pipe washer. I'm sure I'm missing something but that will help get you started.
