Matt Saunoras Posted April 15, 2016 Share Posted April 15, 2016 Would those little 4mm Allen plugs on top of the oil rail cause?I've got an 07 F-450 bucket truck here with what looks like a fairly recent jasper engine in it. Towed in for a no start hot after it was shut off and parked for 10 minutes. I get it, fires right up cold, get my EOT up to 220, shut her down and it lights right back up every time. Can't verify it.However when I let it sit overnight the next day it was slow to build ICP cold, still started but took about 3-5 seconds of cranking to do so. I have seen dummy plugs cause this but I was hesitant because of how new the engine is. Plus pulling the right valvecover with the PTO laying over it made a 20 minute job into a 2 hour job. I couldn't even get the ICP sensor out so I wound up air checking from the left side initially.But of course I did hear an air leak under the right side and when I did finally get the cover off I found that little plug on top of the oil rail was loose and the O-ring blown out.Has anyone ever seen this and if so could one of these little bastards ever be the sole source of a no-start? I actually had a pack of these plugs stashed away and when I replaced it I couldn't hear any more leaks. Checked standpipes and dummy plugs on both sides and all were good. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 15, 2016 Share Posted April 15, 2016 Yes. I used to see a lot of these plug seals blow out on 4.5L engines in the LCF commonly cause a no start. I have also seen these fail on 6.0L engines too but only once or twice. They can act similarly to a worn standpipe or block off seal especially with regard to the no start when hot condition. And I am confident you will inspect everything whilst you are in there. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 15, 2016 Author Share Posted April 15, 2016 Thanks Keith. I'm satisfied for now that there are at least no more leaks under the valve covers. I'm going to put it back together and see what happens. Quote Link to comment Share on other sites More sharing options...
Chase Posted April 18, 2016 Share Posted April 18, 2016 I had one on a 6.0 E van once that was blowed out. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 18, 2016 Author Share Posted April 18, 2016 So far so good, truck starts fine hot and cold, ICP climbs steady like it should. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted April 18, 2016 Share Posted April 18, 2016 Look at an IPR/ICP graph while starting up. A happy healthy 6.0 will spike to 40ish% IPR while building ICP, if it flatlines high at 85% to build ICP something is wrong. We've had this in class and used it for diag on intermittent no-start/hard start situations to verify the complaint and verify the repair after replacing a part. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 18, 2016 Author Share Posted April 18, 2016 The bottom screen shot is what I always look for but many times I've seen the top one and I agree that indicates a concern. I most definitely had a long crank cold that looked like the top. Quote Link to comment Share on other sites More sharing options...
