2006 Posted April 20, 2016 Share Posted April 20, 2016 I've got a 6.4 bus that the cab cannot be removed due to the body overhang and it needs an engine. Anybody ever lifted the engine from the turbo pedestal mount? I though this may save some time, rather than removing the intake manifold and using the Ford lifting brackets. Also looking for any other tips. Thanks. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 21, 2016 Share Posted April 21, 2016 yes I have Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted April 21, 2016 Share Posted April 21, 2016 Here are some photos: http://www.forddoctorsdts.com/topic/4829-cab-on-engine-out/ Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted April 21, 2016 Share Posted April 21, 2016 If you can partial cab lift it can be done without removing the turbos by running a short chain between both pedestal bolts. If you have a bus or some other kind of attached body well then I have no idea but I'd probably be taking the trans out first. Quote Link to comment Share on other sites More sharing options...
