lmorris Posted August 9, 2016 Share Posted August 9, 2016 When this came in to us originally it had an aftermarket seal with a speedy sleeve. One of our techs installed the Ford seal. Now it's back leaking. First I checked to confirm correct installation, as seen in the first picture. Then I checked crankshaft end play, just over 0.0003. Removed the seal and found some gouges on the crank side of the sleeve and the crank is all scored up as well. Not sure who damaged the crank, but I am suspecting this was enough the cause the leak. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted August 9, 2016 Share Posted August 9, 2016 Price out a crank, and quote the labour to re and re the crank. This ought to be good. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted August 9, 2016 Share Posted August 9, 2016 In addition, I'm always suspicious of crankcase pressure with a repeat leak. Probably too late to do a crankcase pressure test....... Quote Link to comment Share on other sites More sharing options...
lmorris Posted August 9, 2016 Author Share Posted August 9, 2016 Price out a crank, and quote the labour to re and re the crank. This ought to be good. Ya, my boss would love that. This is on our dime now. I took the oil pump off and managed to get the scoring cleaned up pretty good and filled in the little gouges with anaerobic sealer. In addition, I'm always suspicious of crankcase pressure with a repeat leak. Probably too late to do a crankcase pressure test....... Thought about that, but in the past they always blow out the glow plug grommet first. Will check after the repair though, just to be sure. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 9, 2016 Share Posted August 9, 2016 This was my front seal oil leak concern, so you never know. http://www.forddoctorsdts.com/topic/5958-stubborn-oil-leak/ Quote Link to comment Share on other sites More sharing options...
