kellyf Posted November 14, 2016 Share Posted November 14, 2016 95 f 350/ leaking oil around plastic piece where dipstick goes in pan. Is this part of pan ,or can it be replaced seperatly? Quote Link to comment Share on other sites More sharing options...
kellyf Posted November 14, 2016 Author Share Posted November 14, 2016 Looks like you can replace parts but pan has to come down. Does it have to come all the way out as parts list no oil pan gasket? Quote Link to comment Share on other sites More sharing options...
lmorris Posted November 14, 2016 Share Posted November 14, 2016 If it hasn't been over tightened and the inner piece is still flat, I have been able to replace the oring with out removing the pan. Leave the dipstick in place to hold the inner piece or use a small pair of needle nose vise grips to hold it from falling in. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted November 14, 2016 Share Posted November 14, 2016 Otherwise if it has been overtightened there is an aftermarket company who makes one that clamps on the outside. The only downside is that you drop the old adapter into the bottom of the oil pan and leave it there till the end of time or the pan comes off. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 14, 2016 Share Posted November 14, 2016 I have never removed the oil pan to do one of these. As mentioned, leave the dipstick installed to hold onto the inner piece. Since I usually had to replace the dipstick as well I found that cutting the dipstick about 6-8" from the oil pan makes it easier to handle and maneuver to replace the o-ring. and then reassemble. DO REMEMBER TO MARK THE POSITION OF THAT INNER PART AS IT CAN GO IN AT TWO DIFFERENT INDEXED POSITIONS. It has to do with the angle of the dipstick which is different for F-Series or E-Series. When you get into the job you will see exactly what I mean. Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted November 14, 2016 Share Posted November 14, 2016 http://www.forddoctorsdts.com/topic/1027-95-f-450-73-oil-leak/?p=54046 The 96' I had to do the pieces were very corroded, I had to re-file the threads on the piece inside the pan. One diesel tech I know cleans everything up & fills the area with that oil pan RTV. Quote Link to comment Share on other sites More sharing options...
kellyf Posted November 16, 2016 Author Share Posted November 16, 2016 Thanks for info! Quote Link to comment Share on other sites More sharing options...
