My 71 F100
forddieseldoctor
I bought a 71 F100 a few weeks ago. It needs some carb work and some trans gaskets. I took it for a ride this weekend and noticed it shifts into 2nd at about 10 mph and 3rd at about 20 mph. It's got a 302 with a c4 in it. Is the linkage that goes down to the trans from the throttle adjust the shift points, or is it just a kickdown linkage?
Vacuum modulator valve controls shift points. The carb to trans linkage is kick down only.
Shifts at those speeds w/o regard to throttle application amount?
Look for trans fluid in the modulator line. I have also seen vehicles where the modulator pin was missing. I guess they fell out when someone changed the valve. I can't remember what they did when that happened, it has been a while.....
  • 6 months later...
Anyone got any tips for getting a seized disrtibutor loose?
I was trying to adjust timing tonight after playing with the point gap and I can't turn the stupid thing. I had the motor hot and hosed it down with deep creep before I walked away tonight.
I haven't gotten around to looking into the trans yet. Got the carb fixed up and been trying to fix a few minor things so I can drive it around some more.
This was common in my salt belt. :( In the past I remember working one until it broke off and attaching a slide hammer to the shaft using a 1/2" compression fitting. I also remember dropping the pan and pump and beating one out from below. :puke:
Points and timing are set. Carb is rebuilt. It runs down the road really good.
Now to start on the trans. I found the kickdown linkage was hooked to the wrong spot on the carb. I figured out where it was supposed to be and got it hooked up right, but it still don't kick down.
  • 4 months later...
I dropped the carrier out of the diff to reseal it. I’m a little confused.... I was told that all the F-series came with 9” back in these years. But according to the tag it’s an 8.7”???
If I look up the part number off the tag it says it’s a 9”.
If I remember right 9 inch differential ring gears weren't actually 9 inches. The ring gear came in a bunch of different sizes but the carrier is essentially the same with only a couple different variations.
  • Like 1
