tonybullitt Posted December 19, 2016 Share Posted December 19, 2016 anyone ever used? I have a modified 6.4 that needs head gaskets and I see alliant power offers gasket kit with studs. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted December 20, 2016 Share Posted December 20, 2016 Personally, I don't use anything other than Ford parts for a repair like that. On the topic of studs on a 6.4... Years ago, I was in 6.4 a training seminar put on by some cats at Blue Diamond. It had techs from dealers, independents, fleets and such. Quite a few people asked why they were using TTY bolts, rather than studs on 6.0s and 6.4s. Their answer was that there is not enough material in the block to withstand the clamping forces of head studs, especially on a 6.4, where the bore and bolt holes are larger; which can lead to a cracked block. I don't know if they were blowing smoke out of their asses, but it is a policy that I live by. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 21, 2016 Share Posted December 21, 2016 6.4s can crack blocks when high tensile strength studs are used. Not the regular ARPs but rather the ones made of tool steel like H11. I would be okay using ARPs and factory gaskets. Anything else belongs in a performance shop. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 21, 2016 Share Posted December 21, 2016 Firing rings. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 21, 2016 Share Posted December 21, 2016 When the arp studs first came out for the 6.0 the torque spec was about 60ft/lbs heavier than it is now. They found the excess clamp loads were distorting the block and deck surface. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted December 21, 2016 Author Share Posted December 21, 2016 we are recommending Ford gaskets and he supplies studs if he wants them installed Quote Link to comment Share on other sites More sharing options...
Jeff Clyde Posted December 21, 2016 Share Posted December 21, 2016 I have used Fel Pro headgaskets on the 6.0 for many years now, and many many trucks. Never an issue, and some of these trucks are putting out some nice hp. Have done two trucks almost back to back that both had Allianz Power gaskets used and only made it 6 months. Mind you, that was a number of years ago, but they were redone with fel pro and no issues since. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted December 22, 2016 Share Posted December 22, 2016 I have used victor rienz gaskets on a 6.0, they looked exactly like the ford 6.4l ones. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted December 23, 2016 Share Posted December 23, 2016 Yes the 6.0 VR gaskets have the same sealant color as the oem 6.4 but the gaskets themselves are slightly different. The pushrod holes are different and the 6.4 gasket doesn't have a notch cut for the standpipe Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted December 31, 2016 Author Share Posted December 31, 2016 Customer supplied arp studs and we ordered Ford gaskets. Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
