8WA Sman Posted December 27, 2016 Share Posted December 27, 2016 I recently purchased a handheld OEM style B crimper to replace the battery cable positive terminal on a late model F-150. I used this crimper http://www.sargen...l_B_Crimp_Terminals/ [sargenttools.com] Sell sheet680.pdf I wish this pic was better quality but... Here is the crimp I made with the tool Voltage drop between B+ and the starter so as to validate the repair. The was peak voltage drop during actual cranking it was closer to .25 volts The part # for the terminal is BT4Z-14450-AA. This is actually listed for a MKX/Edge & the only difference that I found was the nut size. 1 Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted December 31, 2016 Share Posted December 31, 2016 I kinda like that. I wish Ford would make that a supplied tool. Where did you buy it? Quote Link to comment Share on other sites More sharing options...
lmorris Posted January 2, 2017 Share Posted January 2, 2017 Looks like the same crimp made by my VERY old spark plug wire crimp tool, used back when we actually made custom spark plug wire sets. 1 Quote Link to comment Share on other sites More sharing options...
8WA Sman Posted January 4, 2017 Author Share Posted January 4, 2017 I kinda like that. I wish Ford would make that a supplied tool. Where did you buy it?Waytek Inc. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted September 15, 2017 Share Posted September 15, 2017 I bought one of these a couple years ago. I've used it a couple times and it works really well. https://temcoindustrial.com/temco-hydraulic-cable-lug-crimper-th0006-5-us-ton-12-awg-to-00-awg.html Quote Link to comment Share on other sites More sharing options...
batmantech Posted September 19, 2017 Share Posted September 19, 2017 FYI The BT4Z-14450-BA is straight bolt on 7T4Z-14450 is long angle down crimp 2C3Z-14450-ca is shorter turn crimp 2 Quote Link to comment Share on other sites More sharing options...
