Heads up...
Posted on the PTS message board: 2017 F450:
Just giving a heads up, had a unit here 6000km's check engine light and went into reduced power mode. p1291 - Injector high side short to ground or batt (Bank 1). 2 wires rubbed through for #4 injector in the main harness on the edge of the EGR cooler about 6 inches down from pcm connector C1232e. The harness plastic retainer pulls the harness tight against the EGR cooler, causing it to chafe. Going to be other wiring issues caused by this.
  • Like 1
  • 1 year later...
