Popular Post lmorris Posted January 12, 2017 Popular Post Share Posted January 12, 2017 The new internally lubed turbo's on the 2016 6.7L has a different turbo to pedestal gasket to accommodate the internal oil passage. Parts listings here are messed up for F250/350. DO NOT use hardware kit 9T514 on the new designs. The correct gaskets need to be ordered separately and are found in the F450 listings currently. I inadvertently installed the wrong gasket and the turbo lasted just long enough to pass my roadtest then seized up after the customer took it. The correct gasket is HC3Z-6587-A. 3 Quote Link to comment Share on other sites More sharing options...
RyanG Posted January 12, 2017 Share Posted January 12, 2017 That's sucks man but thanks for the heads up Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted January 14, 2017 Share Posted January 14, 2017 Wow, Thanks Quote Link to comment Share on other sites More sharing options...
kridd12 Posted January 17, 2017 Share Posted January 17, 2017 Did that a while back as well. It does suck. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted January 18, 2017 Share Posted January 18, 2017 I bet this has cost Ford hundreds of turbos. It's a shame especially when parts availability is so spotty to begin with Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted January 18, 2017 Share Posted January 18, 2017 So, does it block the oil supply passage? Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
lmorris Posted January 18, 2017 Author Share Posted January 18, 2017 So, does it block the oil supply passage? Thanks for the tip! Yes it does. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted January 20, 2017 Share Posted January 20, 2017 Ordered turbo today thanks for the heads up. My parts guy said the new turbo # did say requires that gasket # so catalogs must have been updated. Quote Link to comment Share on other sites More sharing options...
