tonybullitt Posted February 18, 2017 Share Posted February 18, 2017 I got this truck end of the day Friday Windows inoperable climate control inoperable plus some more issues. I ordered harness per ssm. Has anyone done? does it take care of it? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 18, 2017 Share Posted February 18, 2017 Me, no. What is the SSM? Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 18, 2017 Author Share Posted February 18, 2017 ssm 46329 I am having trouble getting it copied and posted. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted February 19, 2017 Share Posted February 19, 2017 They run can networks to the taillamps now???!!!!!??? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted February 19, 2017 Share Posted February 19, 2017 SSM 46329 - 2017 F-Super Duty - Pickup Only - Loss Of MS-CAN Communication And/Or Other Various Symptoms Due To Upfitter Pickup Box Removal Some 2017 F-Super Duty vehicles where the pickup box has been removed due to amodification, may exhibit various symptoms due to loss of communication on the medium speed controller area network (MS-CAN). Additional symptoms such as climate control system inoperative, front control interface module (FCIM) controls inoperative and/or the headlamps remaining on at all times may also be present. This may be due to C408 being disconnected and interrupting the MS-CAN network when the pickup box was removed. To repair, install jumper harness part #HC3Z-13A409-J into C408, located at the RH rear of the frame. This repair is required as part of the modification(s) and considered non-warrantable. APPLICABLE VEHICLES 2017 TRUCK: FE P558 SUPER DUTY - NA 2017 TRUCK: FE P558 SUPER DUTY - NA 2017 TRUCK: FE P558 SUPER DUTY - NA Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 19, 2017 Author Share Posted February 19, 2017 They run can networks to the taillamps now???!!!!!??? BLIS is available on super duties now Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted February 19, 2017 Share Posted February 19, 2017 They run can networks to the taillamps now???!!!!!???BLIS is available on super duties now I know that. I guess I forgot that the blis system uses the ms-can network. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 20, 2017 Author Share Posted February 20, 2017 I haven't gotten jumper harness yet but it looks like I could pull pins out of c408 and connect the wires. When not equipped with blis the box harness just loops the ms can wires. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 21, 2017 Author Share Posted February 21, 2017 I jumped the pins for ms can and everything works. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 21, 2017 Author Share Posted February 21, 2017 Harness showed up. It appears to be a cab and chassis harness. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted February 21, 2017 Author Share Posted February 21, 2017 On this truck I connected the ms can wires together and heat shrunk them. They are going to put the harness in on the rest of the trucks they are doing. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 18, 2017 Author Share Posted April 18, 2017 We have another customer that got a pickup wants box removed for flatbed. Removed box today plugged in this harness no issues. Truck is equipped with reverse camera. I got parts to order in cab and chassis reverse camera kit pluged right into the harness I added when box came off. I will get the camera kit# and picture tomorrow Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 18, 2017 Author Share Posted April 18, 2017 I had told customer I could make camera work but might have to cut and splice. Pretty cool to be able to simply plug in and mount camera. Camera bracket is a little cheesy but still awesome available Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 21, 2017 Author Share Posted April 21, 2017 (edited) I'm having trouble uploading pictures Got it figured out Edited April 21, 2017 by tonybullitt Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 21, 2017 Author Share Posted April 21, 2017 Here is that camera. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 21, 2017 Author Share Posted April 21, 2017 Took some cab and chassis lights off and temporarily mounted for truck to be driven to upfitter. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 22, 2017 Share Posted April 22, 2017 Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 24, 2017 Author Share Posted April 24, 2017 SSM 46512 - 2017 F-Super Duty – Pickup Only - IPC Turn Signal Indicator Flashes Fast When Pickup Box Removed For Upfitter - No Inoperative Bulbs Some 2017 F-Super Duty pickups may exhibit an instrument panel cluster (IPC) turn signal indicator that flashes fast with no inoperative turn signal lamps after the pickup box has been removed by the upfitter. This may be due to the body control module (BCM) not recognizing the modified lower current turn signal lighting that was installed. To correct this concern, use Integrated Diagnostic System (IDS) service tool version 104.04 or later to configure turn lamp outage settings as required. Under toolbox > module programming > programmable parameters > exterior lighting, select rear bulb turn outage and outage ABM and change the setting on each parameter from outage to no outage. Changes to lamp outage settings on pickups as a result of upfitter modifications are non-warrantable. Upfitters are responsible for FMVSS 108 compliance. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted April 24, 2017 Author Share Posted April 24, 2017 SSM 46387 - 2017 F-Super Duty - Blind Spot Information System (BLIS) Warning Message Due ToUpfitter Pickup Box Removal Some 2017 F-Super Duty vehicles equipped with BLIS that have had the pickup boxremoved for upfitter modification may exhibit a BLIS warning message in the message center. To correct this concern, use Integrated Diagnostic System (IDS) service tool version 104.01 or later to configure the BLIS system. These settings can be found under toolbox > module programming > programmable parameters > warning lamps and chimes and must be adjusted in multiple modules. Details can be found on the truck body builder advisory service (BBAS) website, found by clicking the link at the bottom of the webpage at https://www.fleet.ford.com. Once at BBAS website, click on bulletins, and refer to published qualified vehicle modifier(QVM) bulletin for BLIS warning programming. Changes to BLIS setup as a result of upfitter modifications are non-warrantable. Quote Link to comment Share on other sites More sharing options...
