mchan68 Posted March 1, 2017 Share Posted March 1, 2017 A good customer of ours came in for a Service #2. This vehicle definitely sounds like it has internal base engine issues. It's making almost the exact same rapping sound as one I had apart years ago, where cylinder #8 rod had "s" shaped, causing a piston chunk to be missing along with the cylinder wall gouged. Amazingly enough, that truck drove in like that. I know all too well how the PCM is capable of hiding issues with this engine. It also has some kind of oil leak, just saturating the entire left side of the engine. From what I can see, it's not coming from the turbo crossover tube or any of the CAC boots. Just want some opinions on this. I had thought about possible blow-by getting past the glow plug harness grommets on the left side valve cover. But then if that's the case, why only the left side of the engine? BTW, this thing already had a drop-in installed at another dealer a couple years ago under warranty, not that it really matters at this point. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 1, 2017 Author Share Posted March 1, 2017 Here's how it looks. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted March 2, 2017 Share Posted March 2, 2017 Make sure the dipstick tube isn't cracked. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 2, 2017 Share Posted March 2, 2017 If it is blow by it probably does not matter which side it is when a poor fitting, or not stuck glow plug boot or two decides to vent pressure and oil laden vapors. From looking at the pictures something like that or as Bruce mentioned would make sense given the area and distance the oil mess is from the engine. Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 2, 2017 Author Share Posted March 2, 2017 I checked the dipstick already. Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted March 2, 2017 Share Posted March 2, 2017 Have you checked the crankcase pressure? Quote Link to comment Share on other sites More sharing options...
mchan68 Posted March 2, 2017 Author Share Posted March 2, 2017 That was going to be my next step but the customer declined the diagnosis. Word has it he's going to dump it to get into a gasser like a lot of guys seem to be doing as these rat turds on wheels get older. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted March 7, 2017 Share Posted March 7, 2017 That's all we sell are gassers. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted March 8, 2017 Share Posted March 8, 2017 Good thing I have my gas engine and trans serts to fall back on, the diesel "fad" seems to be ending here as well. ($90,000 price tag is definatly helping that) Quote Link to comment Share on other sites More sharing options...
batmantech Posted March 8, 2017 Share Posted March 8, 2017 Most casual pullers here went to gas already. This diesel market has been shrinking very fast the past few years. Quote Link to comment Share on other sites More sharing options...
YukonTyler Posted March 10, 2017 Share Posted March 10, 2017 Plus the 6.2 is practically bullet proof. So that helps. Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted March 10, 2017 Share Posted March 10, 2017 I can count on one hand the number of 6.2s that actually came through the shop with a driveabilty problem. Couple of broken valve springs and one with water in the fuel. Quote Link to comment Share on other sites More sharing options...
