mchan68 Posted April 18, 2017 Share Posted April 18, 2017 I just replaced my first DPF on one of these. For those of you interested, I have compiled a parts list to save you guys the headache of having to look up these parts yourself, should you ever have the pleasure of having to replace one. By the way, the subframe doesn't need to be removed as the workshop manual directs you to. Only the front engine support brace and right side engine mount needs to be removed, to give you the clearance needed to finesse the whole assembly out. Here's the list: CK4Z-5H270-A DPF/Oxidation Catalyst Assembly (SBS) CK4Z-9450-A Gasket (DPF to SCR Catalyst) CK4Z-9450-B Gasket (Turbo to DPF) CK4Z-9P761-A DPFP 1_2 Nipple CK4Z-9P761-B DPFP 1_1 Nipple AC3Z-5J213-C EGT 1_1 CK4Z-12B591-B EGT 1_2 CK4Z-9B593-B Fuel Vaporizer Glow Plug CK4Z-9D378-C NOx Sensor -W520514-S440 Turbo to DPF Nuts (3 required) -W710382-S900 DPF to SCR Catalyst Bolts (2 required) Those interested, feel free to make this post a sticky. 2 Quote Link to comment Share on other sites More sharing options...
mchan68 Posted December 5, 2018 Author Share Posted December 5, 2018 Okay after my third one done today. I just discovered yet another easier method I thought I'd share with you. DON'T remove the subframe nor the engine support bracket. Remove the wiper cowl, fresh air inlet duct, air cleaner upper and lower housing assemblies and it'll come out the top!!! Some cautions for those of you who choose to try this method. Be careful not to damage the reductant line and injector as you finesse the assembly out and in. Remove the lower bracket that connects the assembly to the lower right of the engine block before going out/in and it'll go. 2 Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted December 7, 2018 Share Posted December 7, 2018 Oh yeah I forgot to post that. I had to do one the other day that we couldn’t lift. And there was no way in hell I was gonna pull a subframe on my back. Quote Link to comment Share on other sites More sharing options...
