mchan68 Posted June 14, 2017 Share Posted June 14, 2017 https://youtu.be/NPmzYpeUtNY I'm wondering if there will be a similar fix for 6.7L trucks? Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted June 14, 2017 Share Posted June 14, 2017 Looks like they put a lot of work in to that engine... Am I the only one that noticed the WIX filter? Quote Link to comment Share on other sites More sharing options...
jimmy57 Posted June 14, 2017 Share Posted June 14, 2017 But why do easily driven highway queens leak at the bottom corner and have unharmed mud dauber nests built in the cells of the rubber rad mounts? I would think others see rough and tumble truck leakers where flex could be it and the ones that are pristine in the wheel housings and frames with seams leaking and have no discoverable issues with t-stats also leaking. Quote Link to comment Share on other sites More sharing options...
tonybullitt Posted June 14, 2017 Share Posted June 14, 2017 Agreed, why would gas radiator not leak if twisting was the problem. Quote Link to comment Share on other sites More sharing options...
forddieseldoctor Posted June 15, 2017 Share Posted June 15, 2017 I think it's something to do with the amount of torque that the motor puts out. Even if you put one of those crossmembers in it's just gonna tear up the next thing in line. Kinda like the frame cross members on semi trucks. The high horsepower trucks tear them out faster. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted June 19, 2017 Share Posted June 19, 2017 Chevy gas half tons have a problem with tank to core seperation. They have actually recalled some. They blame it on excessive thermal cycling due to a faulty thermostat. I would be curious to put temp probes into the end tanks of a 6.4 truck and see what is up. I have changed way more rads on pavement pounders than bush units by far. I don't buy the flex theory. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted June 19, 2017 Share Posted June 19, 2017 Chevy gas half tons have a problem with tank to core seperation. They have actually recalled some. They blame it on excessive thermal cycling due to a faulty thermostat. I would be curious to put temp probes into the end tanks of a 6.4 truck and see what is up. I have changed way more rads on pavement pounders than bush units by far. I don't buy the flex theory. I've always thought it was thermal shock. Shit be boiling somewhere. Something has to give. Quote Link to comment Share on other sites More sharing options...
